Post Info TOPIC: Pressure fans to keep dust out
Planning on out back and top end trips next year .Would appreciate ideas on ways to keep as much dust out as possible.
Someone here has set up a bilge fan blower with filter & wired up to the ignition circuit.
Ours has no fan. Ram air fed.
Cheer,
 Hi Ray...if you enter "Dust" into the search box at the top of this page,you will be able to access a thread started by normiek on July 31st this year. You will then find some ideas that may suit? Good luck.Cheers
Thanks Peter , can you describe how your Ram fed system works ,I am learning as I go?
There is a forward facing grille opening in the front centre of the body. Inside, there is a duct that extends upwards and opens to the inside closer to the roof. That means that the rain can't get in. It has a covering inside of stainless steel fly wire to keep insects etc out.
It also performs the function of the high level ventilation required for the gas installation.
It works!
A mate of mine used a bilge blower with a pod filter set up on the roof of his van.
We have the short snorkel fitted to the roof of the camper , the air enters the camper via an airfilter. Have traveled many very dusty roads over Oz including Gunbarrel, Connie Sue etc and always dust free.
RichardK
RichardK Landrover Discovery 3 2009, AOR Matrix Camper
Peter, Australia is know for it coarse chip bitumen roads, but that's the coarsest I've ever seen!
 Carson Track in the Kimberley. Toughest we have seen.
 So where is the actual Track?  Oh there it is marked out by the oil from torn out sumps! biggrin
