Post Info TOPIC: Isuzu DMax 2013 - remove centre console
I have isuzu DMax 2013 model Auto and want to remove the console for cleaning purposes and install wire to rear of vehicle cabin.
I have searched everywhere for advice but no luck so far.
-- Edited by dickyknee on Tuesday 3rd of November 2020 06:13:06 AM
IG Fraser
Have you tried 'isuzu d'max workshop manual' or words to that effect.
Can I as a D-max owner point you to the IsuzuOz Forum?
Like this one, it is informative, helpful but vehicle specific. There is a General Isuzu section, as well as D-max, MUX sections.
Your question may have already been covered so you might find it with a search. If not, ask & you will receive, I'm certain.
One annoying point is that the forum times out after 60 miniutes; you can log back in for longer periods.
Thank you guys for your help, I will try what you suggest
IG Fraser
Yes, I even contacted Isuzu and they said take it to a dealer. Like bloody hell!
I will never set foot in the Isuzu dealership in  Cairns, Trinity Auto Group. Bastards!!
Terrible service and abusive Workshop Manager.
I will drive to Townsville, 350 km for my next Isuzu.
IG Fraser
Thanks mate, on my way there now.
IG Fraser
Mate,
I can't find the General Isuzu section you mentioned. Can you link it please
IG Fraser
I have removed every panel on my car, more than once! You may need some trim panel clips, as you may loose or break some.
https://thegreynomads.activeboard.com/t65443581/car-acoustic-insulation/
"install wire to rear of vehicle cabin.", I guess you have considered alternatives, for instance running the wire behind the drivers, and right rear passengers door sill trim, may save a lot of work.
The main harness in my car runs along the passenger sill. This is easy to access. Pull off the door seals. You may need to pull off the B column trim panel etc. The panels just need a short sharp firm tug.
