Post Info TOPIC: Ute Canopies
Ute Canopies
Ive just purchased a twin cab ute with a tray back for towing our van, after peoples thoughts between canvas,hardtop or full alloy canopies regardind dust water etc Thanks
GW Cheetham
G'day Graeme,
Go with a full aluminium canopy with lift up sides. Back not all that important.
I had a genuine Holden Canopy fitted from factory but as I get older am starting to regret it. Sadly, it will cost 6-$7,000 to replace now so not worth it.
You will only have the cost of the actual canopy because you have the tray so should be around 2-$3,000. Give or take.
agree with doug aluminum canopy with gull wing doors much more practical an easier to access, the level of fit out will depend on what you require from bare bones storage to a full blown setup plenty to look at on utube for ideas
Hi Graeme,
As usual, I'm a "bit" late with my reply.
When we bought the D-max last year, I looked at getting one of those canopies but I had 2 obstacles. Both started with "P" - price was $12,000 (yes a tray type ute was slightly cheaper), the other "P" was my wife! Getting a dual cab was bad enough, having one of those canopies would have been the last straw!
I got the Isuzu canopy with lift up windows - not perfect but at least I can access most things through the windows.
 One of the most important question that needs to be asked, are you towing a caravan and if the answer is yes then the problems will start as the area is very limited to how much weight you can put in that space.
Now are you going to tow a caravan?
The estimated towball weight and the gross caravan weight?
To get a real answer.
-- Edited by Radar on Monday 9th of November 2020 08:18:01 PM
Full alloy is the the way to go,and easy to get both waterproof and dust proof.NO door at rear though.If you would like details on how to do this,just let us know. Cheers
Status: Online
If you have dogs, definitely the way to go!
Very nice, how much did that set you back, if you don't mind me asking?
Never argue with an idiot, as they will drag you down to their level, and beat you with experience.
Giving up smoking is the easiest thing in the world, I've done it a thousand times
(Mark Twain)
