Post Info TOPIC: Hold downs for draught flaps
Has anybody seen for sale: water fillable soft plastic tubes (6cm dia. x 100cm approx) for the purpose of holding down for draught flaps and bottom annex flaps, when pegs can't be used, eg. Sites with double slabs....
I know a few bricks or logs would suffice, but who want's to carry them.
Daryl
Probably cheaper to buy half a dozen 4L wine casks & recycle the bladder. If that's not enough buy another half dozen or as many as needed!
What about some lay flat 3 inch discharge hose. Fold over the end a few times & clamp. Put in your own filling & release valve connections.
https://www.thornado.com.au/3-inch-80mm-pvc-blue-layflat-hose-lay-flat-dischar~4394
Another idea. Get a couple of PVC ends, & hose clamp them on, & you can mount a garden hose connector at the end on the PVC cap.
https://www.totaltools.com.au/127951-saber-20m-x-50mm-water-pump-discharge-hose-sabdis5020
2 litre plastic milk cartons. Light when empty, handle to tie to and you are repurposing some plastic
Greg O'Brien
