Post Info TOPIC: Caravan Window Thumb Locks
I have been giving the caravan a bit of TLC and whilst cleaning the windows discovered that the thumb locks are stuck on several windows. I have those Camec ones and the windows are the wind out variety.
I know from past experience that any pressure applied results in the plastic thumb lock breaking. Last time it happened I had it repaired when the van was serviced.
My question is this; If I use a bit of WD40 first of all to loosen the slide and then lubricate it with a silicone lubricant will that work. Will the WD40 cause any damage to the plastic. Would silicone spray just on its own penetrate to allow the slide to work or do I need something to penetrate first of all.
The parts are made from a plastic that is unlikely to be affected by most lubricants, but I would never use silicone because once it is there it is virtually impossible to remove.
One of the safest lubricants to use on plastic generally is wool fat.
These parts are just cheap and nasty unfortunately.
Thanks Peter. The lubrication is secondary at the moment. I want to get the thumb lock to slide open. Will WD40 be ok?
Hi DMaxer
I assume that there may be different types of Camec window thumb locks, for the wind out windows
The ones I have, (which also come up when I google Camec window thumb lock), are in the pic below
I would probably describe them, as a lever sliding lock, so they may not be the same as what you have
My Camec wind out windows are a type of clear plastic, the slide locks seem to be of another type of plastic, there is also some rubber involved, to cover the hole in the fly wire, at the lock
I had the same problem, when I purchased my second hand RV
I used a compressor to blow any dust/dirt away, then I used a sparing amount of silicon spray, (I no longer carry the WD 40 type lubricant spray, when I travel)
I can confirm, never to use the Electrical Fast Drying Contact Cleaner. (Some people mistake it for WD 40 lubrication spray), it destroyed a plastic Anderson Plug on my RV
Hope that this info is useful to you
Opps forgetting me manners
Thank you for pointing out, (in another thread), that a Judge can not be given any extra information, after a court case has ended, and before he gives a judgement, it was something I was not aware of
Hi Tony. My ones are a bit different in that they have two ends, a bit like a butterfly with open one way and close the other. Push to left to open and turn other way to close lock.
The bloody things are jammed in the closed and I do not want to put any pressure on them as they break really easily.
They are held in with a pop rivet. Total rubbish.
Try having someone press on the window from the outside. That may take the pressure off and allow the slide to move. With those locks even though the window looks closed up tight often there is a gap of a millimetre or so, particularly if the window is warped slightly.
My locks are the same as Tonys on our van. A few months back the 'hook' broke requiring replacement. The locks are pop riveted on but I used a self tapper screw just in case it happens again!
Murray
I would NOT use WD40. Get some Lanotech.
Yes to that.
Yes to that.
 Hi Dmaxer,
Peter-n- Margaret are correct as above. Lanotech is a natural oil extracked from Lambs Wool. Repco etc sell it in an aersol form, $12--$15 with a fine tube for direct contact.
Grey
The sliding thumb locks are very cheap to buy and easy to fit. If they are playing up drill out the pop rivet, clean the lock and the sill then re rivet in place. I carry a couple of spares with me but find that a clean and refit usually does the job.
Thanks for the great advice. Will keep you posted.
When I replaced mine used stainless pop rivets and lanotech totally fixed problem.
Its the aluminium pop rivets thats the problem.
darjak
Thanks Darjak. I will look into that.
Just thought I would let you know the success of the operation. The thumb locks on the windows of my van were virtually welded shut. I could not move them a millimetre and any force would have resulted in them breaking off.
As suggested by the forum I used a lanolin based lubricant called Lanex and after a couple of applications over an hour or so they all moved freely. This is really good stuff, thanks for the tip.
