Post Info TOPIC: Victron IP67 240 Volt 25 amp battery Charger
Good afternoon to all My Projecta 25 amp Charger has quit , so my 12 volt shop recommended a Victron IP 67 25 amp charger. It looks a very solid unit with a 5 year guarantee and is better value money wise. These are controlled by blue tooth. I have two 105 amp AGM batteries connected parallel.. Should I set this charger on Normal which has an absorption rate of 14.4 volts or High which is 14.7 volts The float rate is constant at 13.8 volts and the storage rate also constant at 13.2 volts . ??? Cheers daz
the seconds keep on ticking away
Hi dazzsmile
The correct answer is to ask the battery manufacturer/supplier which voltage to use or look on the battery itself(s) as it is often printed on there near the brand on the side.
You will get 10 different answers on the forum because we do not know what you have ? biggrin
The answer to your question is YES. 1 simple answer, not 10.
 Another useless post which gave absolutely zero help to the member
.Why don't you get a life????noconfuse
