Post Info TOPIC: Swift ecotherm heater
Just took delivery of our new 18'6" van ,looking at off road/ free camping heating anyone with experience with the the heaters that run off your hot water system.would appreciate any advice
Welcome to GN's,
Unless you are constantly hooked up to a power supply - You'll go through a lot of gas heating water just to run an inefficient heater. If your hooked up to power you may just as well run air-conditioner or a small space heater.
Gas heating is most efficient although gas can get expensive out back.
Diesel heating is efficient - but just a bit tricky servicing and keeping it running well. (Noisy if camped near others)
We tend to camp in the bush and utilise camp fire for ambiance and warmth - put a billy on to fill hot water bottle to go to bed - really cold use genny and small fan heater or airconditioner
Cold mornings, I get up first put kettle on stove to make tea - cook either toast or porridge the van is warm enough for child-bride to arise, then enjoy mornings sitting outside in sun and breakfast with child-bride
"Cold mornings, I get up first put kettle on stove to make tea - cook either toast or porridge the van is warm enough for child-bride to arise, then enjoy mornings sitting outside in sun and breakfast with child-bride"
Yeh that's what I do if I'm on my own. But gas heater if SHMBO is in residence.
Sta
 They work like your car heater does, blows air thru a radiator of hot water. Does not use as much gas as a solely Gas heater, as hot water circulates back to HWS, but not as efficient as a diesel heater.
Very clean and enviro friendly, no smells etc.
Cheers Bob
Make it Snappy......Bob
My brother had one of the hot water/heaters in his 21ft van and found it fairly useless, it just didn't put out enough heat to do much. In a smaller van it may be better, but personally I, and him in his new van, would go for a diesel or gas ducted heater instead.
You lucky bast_rds, we get up in the morning, after sleeping in the car, have to go outside for a w.....
We have stuffed the car full of acoustic insulation which also works brilliantly as thermal insulation, also all windows are covered which dramatically reduces heat loss & stops condensation. At 0°C outside we don't feel that cold in the morning.
No contest: go with a diesel heater.
$200 on e-bay and if you can use a few hand tools easy to install.
Uses very little fuel (125ml per hour) and runs very quietly.
Nothing else comes even close for small space heating.
Thanks to all ,looks as if the diesel heater wins .It's great to have such a knowable brains trust to help
