Post Info TOPIC: Telstra Phone coverage booster
Hi All
I would like to buy some form of booster, I can get 3G outside the van with a poor signal but nothing inside unless I put the phone up in the vent, not that easy getting my head in there as well. Anyone know of a good system to boost signal.
Perry
Perry wrote:
Hi All
Cheers.Perry
 Hi Perry....Cel-fi Go is the go! Expensive,but I get good coverage even when there are no bars on my phone,and absolutely no signal until the booster is turned on.Cheers
Hi Perry
3 things.
1. how old is the phone?
2. who is your provider?
3. where are you located?
The reason for the questions is dependent on what you will get.
If you are with Telstra you need a BLUE TICK phone as it will boost the signal as they are more powerful. I dont know if the other providers supply blue tick phones. mght pay to ask. I travel all over and have had very little problem with reception on phones or mobile internet except in the known black spot areas.
Hope this helps.
Col
ColB
Landcruiser 100 series towing a 9.5m Coromal Capri 780
The Blue Tick phones do not have a booster, they do have a slightly better antennae than some other 'phones. "Blue Tick" is simply a Telstra advertising term.
An high mounted external antennae will give a better reception, particularly if your 'phone can accept a 'plug-in' version. Otherwise a patch antennae may help. Again, these are not "boosters", just better antennae.
The Cel-fi Go is the only legal booster as far as I am aware. $1000+
I have an aerial attached to my TV aerial
Was great with the old telephone that had a patch lead input
Now with an IPhone there is not a input for the patch lead
I had one telephone that did not have a external input but if you took the back cover off there was input
Drilled a hole in the removable back cover to insert the patch lead
If you got a Iphone you can get a cradle that the patch lead is inserted but some not great reports
Here's a useful link.  I find that Whistle out is a good and unbiased source of general information on Australia mobile issues...
https://www.whistleout.com.au/MobilePhones/Guides/telstra-blue-tick-best-phones-for-the-bush
or this one from Telstra on extenders
https://www.telstra.com.au/coverage-networks/network-coverage-extension-devices
Edit .. I forgot to mention that a year or so ago when I was looking for a new phone & service provider (eventually chose Boost on price & coverage) I got into the frequency bands used by each of the networks across the nation and most importantly the frequencies supported by particular AU releases of phone brands & models.  Quite a complex arena but worth the effort.  The Blue tic & Optus equivalent take the hard work out of much of it I suppose.
We have an unlocked Telstra blue tic phone as well as an iPhone10 but haven't carried out any comparative tests or checks.   If the iPhone doesn't have coverage, I can change the data rich sim (plan) into the Blue tic phone & hopefully, away we go.
Interesting to note that the race for country coverage has quickened up a bit with Optus belatedly scrambling to provide access in some country areas that Telstra bypassed in the past.  It pays to get the most recent coverage maps if phone coverage is really that important to you.
-- Edited by Cupie on Thursday 30th of July 2020 10:22:22 AM
-- Edited by Cupie on Thursday 30th of July 2020 10:23:48 AM
as Pete said Cel-fi Go is the way to go , there are others out their but to my knowledge that is the only one that is legal to use . there has been another one advertised on tv lately but i havent looked into it or even remember the name , someone else may be able to shed more light on it .
Ditto 90cm mobile phone aerial on top of my Winegard TV aerial connected to a Blue Tick phone with aerial socket, also have a Telstra Modem with aerial socket.
Mate puts his Modem on top of a 21ft pole ( 2 sections carried under van when not in use) for data and can use Viper? for calls as well.
-- Edited by PeterInSa on Thursday 30th of July 2020 10:58:06 AM
 We are both on Boost & now both of us are on 1 year plans $150 each. We don't use a lot of data. All the free calls to the Countries in Europe we need included.
Call #111# to check your remaining data.
If I think I might run a bit short I can start using other half's data, or vice versa. But so far using less than a month's average.
Cheers,Peter
 Yes,when I was researching boosters I found some that were waaay stronger than the Cel-fi Go that I ended up with,but I was also told that they were illegal,and somehow limited service to other phones in the immediate area? Mine cost $2000 with extra aerials and another repeater(?) for better reception in the van.My aerial is a fold- down model,and is over 4 metres above ground level,on top of my car's canopy.Works well. Cheers
Mobile cell boosters are sold cheaply on e-bay but they are not approved for use in Australia. Do not buy one. The ACMA *will* track you down quickly and they *will* confiscate all your phone equipment and may well prosecute too. There are extremely sound technical reasons why such unapproved boosters should not be used.
Blue Tick phones? Yeah, maybe, perhaps.... Last I heard it had to be the same bloke in Telstra's labs who did the Blue Tick test because the body reactance of other individuals gave different results, which is predictable.
A trick which usually works in poor signal areas is to put the phone on hands-free and prop it up vertically on a table and make calls without touching the handset - apart from dialling of course.
An advertiser at the top of this page sells phone boosters also I think Telstra and Optus sell one but they are all expensive and will end up around $1k.
Finding a handset with provision for an external antenna is all but impossible it seems these days, sadly.
 Yep...  I got exactly the same advice contained in paras 1 & 2 when I dug into the subject a couple of years ago.
BTW, I had a great deal of interaction with the old & highly regarded Telstra Lab many years ago and what a stirling group of people they were.  I think that they were headed up by (I think) a Dr.Wragge?  Their brief was to look out for a minimum of 10 years.  Bloody hell who could predict Telecommunications developments 10 years out? The regular internal lectures that they gave were outstanding & laid a platform for the company's strategic, marketing etc directions.
A mobile phone induction antenna was installed in Cleve Cole hut on Bogong. It made no difference to my Blue Tick phone but it did to others.
Cheers, Ziggy
