Post Info TOPIC: How to fix coaxial to Clipsal
Hi all
Can anyone help me know how to connect the coaxial cable to this clipsal tv external socket?
Also, how to assemble the square bit into the housing?
Can't find a video.  Thanks heaps,  Ken
Try download.schneider-electric.com/files
The end fitting is the confusing part - its not the usual terminate and screw in
It is not meant to be used as a permanent means of attaching a cable to socket - it's meant as an external plug in.
https://download.schneider-electric.com/files?p_Doc_Ref=CLPDOC_W0000561&p_File_Ext=.PDF
Sorry Ken - "Whenarewethere"s post makes it clear - As usual I had the Bull by the tits - I didn't grasp your meaning until I saw his post.
Hi all; And another way to connect coax cable to a outlet, this way you would also be digitally correct.
-- Edited by valiant81 on Tuesday 14th of July 2020 10:28:01 AM
 and only use compression fittings, do it right the first time
blaze
