Post Info TOPIC: Replacing caravan side lights - non LED
Hi all
I'd like to replace a non LED side light
I'd like to buy the non LED to match
Any ideas on who would sell those?
Thanks,  Ken
try caravanplus.com
blaze
-- Edited by blaze on Monday 22nd of June 2020 08:42:08 PM
Most Jaycar stores will supply the globes at a fraction of the Caravan Supplier cost - although if you need to replace the actual light fitting you may need to go to Camec or Caravan plus.
HI
Plenty of Both bulb and LED types
www.narva.com.au/categories/lighting/truck-trailer-lighting/marker_lamps
If not replacing with the same unit check to make sure LENGTH WIDTH SIZING is the same or larger to cover wiring hole and old screw holes .
Solder and heat shrink wiring
Attach light and seal with this Sika Sil Industrial [used for Van construction ] Bunnings order in 6$ a tube tradies.sikaretail.com.au/products/sealing/external/sikasil-industrial/
G'day KenG,
You might be lucky & find new light fittings that will fit perfectly, some you may have to "do some fiddling." As swamp said, there are bulbs that fit the standard 12v holders but you may have to add a piece of mirror behind them to get maximum reflection.
