SmartBar
Post Info TOPIC: Interior wall decals
I am looking for some wall decals to brighten up the interior of my motorhome and cannot find any in Australia. Can someone please help?.
If you make a vector file, Adobe illustrator or similar, then take it to a sign writer.
Hi Spike,
Can you get some stick on hooks from a hardware store & hang up some small pictures, photos of your family?
That way you can change them from time to time & not worrying about trying to remove the decals later.
Of course, you'd have to put them on the bed, in a drawer when you travel.
Hi Philip.  Have PM'd you.
If you want pictures get a printing shop to bond picture to a piece of 3mm Forex sheet & laminate the surface. Use original adhesive Velcro not the cheap stuff to stick pictures on wall.
Just a bit of advice from a retired signwriter of 45 years. You should be careful putting stickers on the wall of your motorhome as you may not be able to remove them without damaging the surface. My caravan for instance has paneling that is basically a fake timber pattern that would most likely peel off if I tried to remove a sticker. This could prove very costly. Remember if they wont come off and you want to sell then not everyone will like your stickers. Before going down this track check what the surface of the panelling is. Hope this is of help.
Living on the Gippsland Lakes Victoria.
 This is what happen to us, the previous owner had place those good brand stick on hooks around the walls, including a couple stickers. When I went to remove them the white veneer come with the sticky leaving horrible blemishes here and there.
58048c4f11d79d20f9980c17-3-large.jpg57972ba19649170b6b2fa76d-contest.jpg59e5ee8c0d18824c9551f656-0-large.jpg5e50c7256e3b903d17577710-0-large.jpg5d89dbeaf35cf94e02718626-11-large.jpg5e141c54d143ad02a02afd0a-0-large.jpg5cb9342cdabad4764748b454-3-large.jpg5be1336029fb157147284f6e-0-large.jpg5ae558490de05573393a1776-5-large.jpg
Some nice ideas there Sherba. Thank you.
I am not very artsy, its a one day job for me, probably when I go to sell the caravan.
