SmartBar SmartBar
Post Info TOPIC: HWS Pressure Relief Valve
We have a Suburban HWS and during a recent trip the Pressure Temperature Relief valve started dripping and is gradually getting worse. I bought a new valve but are having difficulty in getting the old one off. By the state of the anode I replaced recently I am guessing that there maybe some corrosion to the internal thread of the PTR valve. Have been soaking in WD40 for some time but still wont budge. I am worried that if I give it a real go, I will probable stuff the threads completely. Anyone got any ideas would be appreciated thanks
Try a plasticine dam around it & use penetrene overnight, judicious use of a small gas torch around the area may help, could soften any sealant that was used on fitting, I find penetrene still one of the best, Joda.
J. Price
I would also turn the HWS on, let it heat the tank up, then TURN the HWS OFF ( power and gas) and try again maybe the extra heat on the thread will help to get the old valve out.
Make sure you relieve the pressure if you switch the heater on before you unscrew the relief valve, open the hot tap & relief valve!
J. Price
Reducteur Super release agent is the best stuff to loosen frozen nuts or studs, not cheap but very effective.
www.bunnings.com.au/reducteur-300g-super-rust-release-agent_p6100255
thanks everyone for your suggestions, will let you know the outcome
