Post Info TOPIC: Batteries on parallel
we got two batteries same brand same voltage the only difference is one is rate 10 hr the other one is 20hr can them be join on parallel thans very much sorry about my english
Your English is much better than my Spanish! :)
Yes, you can join your batteries in parallel without any problems.
Thank you very much i appreciate your respond to my not very clear question  thans Mike
You can connect the two batteries in parallel to achieve more amperage at the same voltage, however having two different Amp hour ratings on the batteries may allow one to absorb the charge current at differing rates, ie one may actually rob the other due to the differing capacities of the batterys.
It is always more prudent to use two identical type, amp hour rating and age of batteries together for long life and reliable performance.
In your case coupling the two batterys will limit the life of at least one of the battery's.
regards Ross.
Ditto.
I'm going with Bushbased.
