Post Info TOPIC: Rear View Mirrors.
Rear View Mirrors.
I have little tolerance for TV ads that are untruthful or inaccurate. As a Grey Nomad the Holden Trailblazer TV ad annoyed me.
The ad  clearly show the Holden Trailblazer towing a Trailer/Caravan that is clearly wider than the Tug.
My understanding is that Australian ADR's clearly state that you must fit extended Mirrors to enable the driver to see down the sides of the Towed unit. I did some research looking at various State rules about this.
Being a Grumpy Old Man I complained to the Advertising Standards people.
Imagine my surprise when Holden's response was that the NSW Rules state  "If towing a trailer wider than the towing vehicle it MAY need extended mirrors"  It actually goes on to state that you must be able to see down the sides of the towed trailer.
My complaint was dismissed.
The following was copied from a Govt website about Towing a trailer in Australia.
Assuming that your chosen tow vehicle complies with the ADRs, it is your responsibility to maintain that compliance. When you hitch up a caravan, boat or other trailer to your tow vehicle, you potentially block your vision of the areas specified in the ADRs. If the trailer is no wider than your tow vehicle, then it is likely that your standard mirrors will be sufficient; but if the trailer is wider, then you will need to fit extension mirrors.
A simple test would be to attach your trailer to your tow vehicle and stand directly behind each of the rearmost corners of the trailer at a distance of about 20m from your side rear-view mirrors. If you can see each mirror in its entirety, then you are likely to be compliant. If the mirrors are partially obscured or completely hidden behind the trailer, then you must install extension mirrors.
Some people will argue that they have a camera fitted on the back of their van and that it provides the additional area of vision required. This is not the case. A camera will show you what is directly behind the trailer but not the crucial areas alongside the trailer and its rearmost corners. You need to have vision in these areas when changing lanes or merging into traffic in order to avoid a collision.
I rest my case.
G.O.M.
At times I am astonished when I see the number of vehicles towing caravans without extended rear view mirrors.
I think it would be an advantage to have a warning somewhere on or in each caravan. Ther would not be many vans that are the same width as the towing vehicle unless the towing vehicle is a Kenworth or similar.
I guess that some are just lucky that many police patrols are not that observant otherwise revenue figures would be on the increase.
Rob
-- Edited by bentaxlebabe on Tuesday 5th of November 2019 02:05:42 PM
Rob
Chairman of the Bored
Whether the Holden ad is right or not, it is not a good look & does not encourage responsible operation of a car.
Just an addition to my post re Mirrors.
I've lost count over the years of the number of rigs without extension mirrors, overtaking me and staying out in the overtaking lane, precisely because they have such limited rearview vision they cannot see me to know when it is safe to return to the left lane.
 You're right there,Trevor! From my years driving B-Doubles interstate,I can say that the other tourists that are a problem are those who seem to forget that they are towing a van,and immediately cut back in front of the vehicle they have just overtaken,often before the caravan has passed the front of the Kenworth! Fun and games for all! Cheers
The new Actros Mercedes Trucks don't have rear view Mirrors I have a camera on the back of my 5th wheeler REG in VIC tug REG in WA NSW licence I tell the office I am Australian
No one ever told us this when we were selecting the bride.
Rob
Rob
Oh Heck,
Angie may see this.
Rob
Rob
ITS A ADD
you don't really believe that they drove a car into the back of a caravan to hide it from the police as well
really
d
trouto wrote:
ITS A ADD
really
 Say what ??
Rob
-- Edited by bentaxlebabe on Tuesday 5th of November 2019 09:39:03 PM
Rob
 I just had a look at the new Mercedes Actros
Scroll about half way down to view the mirror cam
https://www.mercedes-benz.com/en/vehicles/trucks/the-new-actros-2019/
What type of vehicle are you hauling the  fifth wheeler with Ilochris?
Rob
Rob
I have spent considerable time and effort researching this issue. Out come was the regulation is "must be able to see a vehicle overtaking on both left or right and approaching from the rear. " The statement about mirrors was described to me as an example if you wish to use mirrors only. I might add I have been questioned at breath test stops in most States about no extension mirrors. In all cases police commented that my camera with existing car mirrors is a far better option. Not everyone will agree but then again some people believe if it has worked for 40 years it must be the best. I also believe it is a no brainer not having a reversing camera and/or sensorors on rear of your car. Neil
 A friend of mine was booked in Qld for not having extended mirrors, he told the copper that he had a camera. Had to pay the fine.
 Your mirrors must give you a view of both rear corners of your caravan.If you stand directly behind your caravan,20 metres from your mirrors,and look along the wall of the caravan,you must be able to see your rear vision mirror in its entirety.Cameras are handy for observing cars under your van's rear bumper,but are useless for seeing what is alongside your vehicle,or keeping an eye on the van's tyres etc. I seem to recall reading....and don't quote me...that it is illegal to have any camera display on a screen that is visible to the driver whilst the vehicle is moving forwards? I will do more research on that.Cheers
P.S.Australian Road Rules clause 299,but no doubt open to interpretation?
-- Edited by yobarr on Wednesday 6th of November 2019 12:30:22 PM
Most mirrors are convex and therefore you can see the side of the van and quite a distance outwards as well.
With a rear view camera, I can see everything that comes up behind me and in the next lane as well.
Cheers Bob
Make it Snappy......Bob
You can always tell when a tug hasn't got suitable mirrors - because they have no idea what is alongside them they turn on the indicators for 30 seconds to a minute to allow other vehicles to get out of their way before they change lanes.
If you challenge them about inadequate mirrors they will say that they have travelled x number of kilometres without any problems, so what is the big deal about mirrors?
At the very least I don't see how they can pull away from a kerb safely without knowing what is coming up behind.
Murray
I know what your getting at Yuglamron but me, I don't take too much notice of those sort of adds in fact, many adds at all. I gave up believing them many moons ago. Especially the ones where a big name celebrity gets on the box and says a product is great and they use it all the time. Bollocks! They only say that because they get paid well to say it.
As for towing mirrors I don't see a problem using them at all, law or no law. The cost of a set of towing mirrors is neither here nor there really so I put them on all the time. That said, I used clip-on ones every time anything wider than the car was connected but when I went full time on the road as a GN I lashed out and had Clearview mirrors fitted to save putting mirrors on and off all the time as you can't drive around with clip-on ones on when not towing. The Clearviews stay on all the time and just with a little push or pull they are adjusted. Yep, cost more but when full time out in the playground worth every cent IMO.
I also have a camera on the back of the aluminium teepee and can see everything behind and until the car has just gone past me if overtaking that's where the tow mirror takes over. I like to see where I have been as well as where I am going.
I too am quite happy using extension mirrors, the LH one I have set so I have a good view of the van wheel, so I can see how far I am from the shoulder of the road. As for using a reversing camera while driving, I would say what yobar said is correct, probably because you don't want the reversing lights to be on. its a matter of a name change to "Drivers aid" and the rear camera is quite legal.
It is illegal to have a video screen visible to the driver. It is legal to have a screen as a driving aid, such as gps and rear view. Neil
Qld legislation (road rules) states at clause 299.1 that a screen visible to driver is illegal. Clause 299.2 states that clause 299.1 DOES NOT APPLY if the screen is a driver aid. In that clause it gives examples of legal drivers aids. Rear view screen is listed so therefore LEGAL
Inserting some pics for someone that was interested.
