Post Info TOPIC: LC versus Dmax.
LC versus Dmax.
Hi All,
i have a 2018 Dmax pulling a Kingdom Kensington 1860 T, for the next longer trip Im thinking of changing to a 2nd hand Cruiser,
Thoughts  are,
1st Dmax (2014) cracked head at 70000km ,fully serviced above and beyond. The failure is always in the back of my mind,yes I did but another one.Fuel economy is fantastic without van reasonable with.
isuzu not interested in warranty .
LC , I have had a 60 ser and 80 ser a long , long time ago bothe sold with 300 k plus never let me down.
What are the V8 LC doing per litre with a similar weighted  van and how is the general feel out there for common rail / injector problems and so on.
any one selling a good one.
rbudnick
Rasty wrote:
Hi All,
Thoughts  are,
 Hi Rhys....DMax and V8 Cruiser are chalk and cheese.Whilst the DMax is certainly one of the better lightweights,the Cruiser is a different vehicle altogether. When I bought mine,one of the first things I did was to fit another fuel filter BEFORE the factory filter,and I then got a tune done by a reputable Diesel Tuner......huge increase in power,torque and fuel economy.There are many thousands of these lightly stressed V8s towing much bigger loads than you have,with no problem.Where in Australia are you based? Cheers.
Hi Rasty.
I can't comment on Dmax v LC as I have never owned a Dmax.
But; re fuel, my van, duel axle, 8 mtrs total length and is 2500KG loaded.
I use cruise control most times and sit on 100km`s/hr. (when possible)
I only us BP fuel, and my fuel consumption on average is 16.4ltrs/100km`s. Ideal conditions.
Hope this helps in your decision making.
However a BIG plus for the LC is comfort.
Regards.
Hetho.
Hi,
Hetho, what are you driving please?
I have just today sold my 2012 Dmax to a friend at work....now have the same type of desicion to make.
I have had absolutely nil problems with two Dmax Dual cabs over 10 years but time for a change and I prefer Wagons.
Either a 200 series, Nissan Patrol, 76 series, 79 series dual cab or a new model Dmax(out in April/May). At the moment leaning towards the Nissan as no DPF filters or worry regards diesel fuel quality but I have not quite got to the point whereby i'm going to buy one. I do know will cost more for fuel but offset by cheaper servicing.
The Toyota's are very pricey for what you get due to being stand alone in the market place in my opinion but I do like the 200 series.
I like the Jeep Grand Cherokee but the uncertainty regarding reliability and part supply would cause me to not to buy one.
What to do....
Cheers AL
Hi Al.
Im in a 2013, 200 Series Landcruiser, GXL, 4.5 ltr twin turbo V8, Diesel. 210000kms. Purchased new with an employee (not Toyota) discount of 30%.
It was too good of a bargain to refuse.
The only issue has been the front brake rotors which develop heat spots quite quickly. Im trying softer pads now to see if that will help.
But very comfortable and heaps of room. I normally run with the 3rd row of seats out.
Regards.
Hetho.
-- Edited by Hetho on Tuesday 29th of October 2019 01:52:10 PM
-- Edited by Hetho on Tuesday 29th of October 2019 01:53:00 PM
sandgrooper1 wrote:
Hi,
What to do....
Cheers AL
Hi Alan....the car you choose may well be dictated by the van you tow,but if you had a DMax,it can be assumed that your van has an ATM no more than about 3000kg? The 200 has a rear axle capacity of only 1950kg,and tares heavy,so that is something to watch.Apart from using fuel like it is going out of fashion,the Y62 also has limited towing ability,as GVM drops to 3370kg with 350kg towball weight,and 3430kg with 300kg TBM.Maximum weight on wheels,with absolutely perfect axle loadings,is only 6520kg.....light years away from advertised 7000kg.The LC76 also has GVM of 3060kg. As always,79 series is in a class of its own,with 2300kg rear axle capacity,which means you can load the car up so always it is much heavier than the van,and much safer.My neighbour recently used his Y62 to go to Cameron corner etc,and when he returned he had to consider selling his house to pay the fuel costs on his credit card.....and he was towing only a camper trailer! Good luck with your choice.Cheers
P.S "Toyotas are pricey"?...one of the first lessons in life is that you get what you pay for.Just saying.
Hi,
Thanks Hetho.
Yobarr, The caravan I tow is in my avatar, a 2008 21 ft Windsor Genesis. It is about 2.6 t loaded for a trip. Eventually that will be changed as well though.
My 2012 Dmax has done it quite well only real issue is a rather tall first gear which gives the clutch a workout on hill starts. I try to avoid them.
Yes the 79 series is possibly the most tow worthy of my selection but not a favorite of she who must be thought about.....
From what I have read and talked to owners about the Y62 series 3 and 4 are only a whisker more thirsty than the 200 series when towing...maybe a litre or two per 100 kms.
Around the town and no load, for sure the Cruiser is more economical.
Sorry if I have hijacked the thread but it is fairly relevant to the original post.
Back to putting the thinking cap on...
Cheers AL
sandgrooper1 wrote:
Hi,
Thanks Hetho.
Yes the 79 series is possibly the most tow worthy of my selection but not a favorite of she who must be thought about....From what have read and talked to owners about the Y62 series 3 and 4 are only a whisker more thirsty than the 200 series when towing...maybe a litre or two per 100 kms.
Cheers AL
 All good Al....any of the cars you have selected will comfortably tow up to about 3000kg ATM,but after that,the only suitable options are the Y62 and the 79.In view of the your wifes  apparent aversion to the 79,which may lack some of the preferred but unimportant "luxury" items,it seems that your choice is limited to the Y62.Good car,but not my kettle of fish.Good luck with whatever you choose! Cheers
Hi Rasty,
When I brought my first 80 series LC, I asked the salesman what it was like on juice? He said if you can afford a Cruiser, you don't worry about fuel !! Back in those days fuel was cheap, now I'm on my fourth LC.
I have a 2015 LC 200, 4.5 V8 TD done 80 k and is a joy to tow with. Usually get around 18 -19 LPH, doing 100kph on cruise control also, it has been as bad as 23 - 24 LPH with terrible headwinds etc but a comfortable ride that always feels very stable and strong. I tow 3200 kg.
Cheers Bob
Make it Snappy......Bob
Don't you mean all not some no
Bill B
For some it is the case.
 I've fine tuned that saying to "you get what you can afford".
its a no brainer
go the dmax
Toyota is just over rated and talked about
blaze
blaze wrote:
its a no brainer
go the dmax
blaze
 Over rated and talked about indeed! Perhaps can you explain why Toyota can't keep up with demand,and there is a 6 month waiting list to buy a 79?  The Cruisers seem to retain their value too,as evidenced by the high prices realised in the second hand market.I seem to recall that the OP already has a DMax,is unhappy,and seeks a superior vehicle? Tony opined that "....you get what you can afford",which undoubtedly is true,but I would suggest that a second hand Cruiser would be a safer bet than a new lightweight? Cheers.
I sold my Landcruiser and brought a D-max. Happy as! To crack the head l bet it was runnging hot or you were seriously unlucky.
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
To me (predjuiced) the LC200 is great, but even given your lightweight van, be careful of creating a " FAT " cruiser. easy to go over gvm on cruiser with all the good stuff, once you add tow ball weight. We get between 17 sometimes to 18-20 l/100 towing around 2100k pop top. Try to keep around 95-100 indicated.
Cheers Craig
blaze wrote:
its a no brainer
go the dmax
blaze
 Why buy a dual cab ute, have no security in the tray, then put a canopy on..............buy a wagon instead.
Oh what a feeling.........biggrinbiggrinbiggrin
Land Cruiser every time.
I wasn't going to join in on this topic as you asked about Toyota or Dmax but hey, me being me I couldn't help myself sorry.
I am a very happy Colorado driver and it copes very well with towing 2.7t. The Collie is loaded 24/7 as I am full time on the road.
I can't see why the Dmax wouldn't do what you want. Maybe consider putting a tray on back with aluminium canopy (Shed), that way things are easy as to get in and out. I went with a genuine Holden Canopy but regret it now and too costly to change.
Another thing to think of is, with the Shed on the back you have your 'Man Shed' with you at all times. biggrin
Chief, does that include a ( VICE) ?
Cheers Craig
No sorry Craig. I don't have the 'Man Shed' so NO vice.
The 'Man Shed' is the way to go though.
 Agreed....and I do have a vice,along with almost any workshop tool you could name.Taps and dies,bearing pullers etc.And 120 litres water under the floor,along with a 36" stilson....don't ask me why! Cheers
-- Edited by yobarr on Wednesday 30th of October 2019 03:49:25 PM
 My mate has a 3000kg jb caravan he used to tow with a dmax. He was sick of arriving at destinations with white knuckles from holding the steering wheel so tight.  Frustrated he asked to borrow another friends 200 to test tow the van with. They drove around for about 120 kms. The difference was so great he had a 200 in his garage 2 weeks later !!  He is happy as too. Regards Pete
Rasty wrote:
Hi All,
Thoughts  are,
 To answer your questions I have a 79 series v8 ute towing a 3300-3500kg Kedron, I use 17-20 l/100k, some days more some less. My vehicle has 130 000 kms up to havent  experienced any common rail or injector issues.   And every thing I own is for sale, at a price !!   Too add we have a 2007 79 series v8 at work with about 470 000 kms on it, it has never had fuel syste troubles ever.  Actually no issues at all.  Regards Pete
Hi rasty, I went from a brand new 2011 D max to a 2012 landcruiser. Max had towed our van through warri gate strez and Odnadat tracks went to the cape done OTT towing our off road camper and a hell of a lot of the high country. In late 2015 just before i got sick sold Max and went back to a cruiser 2012 gx it has towed our van along the tracks the gulf country and back to the cape outback QLD etc etc
Would I go back to a Dmax. HELL NO. (power and comfort.)
As stated previously, you get what you pay for, LC200, expensive but wow what a car!
I have to agree totally with Hetho here,  also have a 2016 VX Cruiser, and the same fuel consumption 16.4lt/100 average. I tow a 22ft van, so the weight is up there.. But tows like a dream, plenty of power should I need it. These are proven vehicles, and yes not cheap, but a very comfortable ride and with plenty of space..
Branchie
KB
Yep,seriously unlucky,interestingly I had filled up in a large service centre on a hwy nth Nsw then headed to Lightening ridge , after 200 km the car didnt hold as well in top gear (auto) changed filters (gen)a bit of nulon diesel conditioner and a slight improvement.
Wyong a few weeks later everything running fine but pumping water all down hill from there.
it was suspected that the Egr cooler was the starting point of the problems ,note the last few models have coolers nearly twice the size.
no interest from Isuzu but thats much the same with any Manufacturer.
rbudnick
They dont want to admit they are fragile or durability issues. Im glad I have a motorhome! Lol
Hi all,
As a footnote to my post, a Y62 Nissan Patrol has been brought to replace my Dmax.
I must say I never had any white knuckle towing issues with my van on the road towing with the Dmax, did the job well.....but I think any caravan much bigger would have been asking for trouble weight wise van vs tow unit if an emergency situation arose.
Overall two Isuzu Dmax dual cabs over 10 years plus and not one problem is a good/unusual thing to be able to report.
Just waiting now to get the Patrol. Hopefully as trouble free as well.
Cheers AL
