SmartBar
Post Info TOPIC: Lifting Poptop
Lifting Poptop
Having difficulties lifting my poptop on 2014 Jurgens Wallaroo. Anyone have experience with newer lift bars or the air jack systems..? or any other advice for a DIY solution preferably.
-- Edited by Mindi on Tuesday 16th of July 2019 01:31:12 PM
Hi. When I put a 200w solar panel on the roof of my pop top I found it much harder to lift up. My solution was to replace the gas struts to a heavier Nm rating. Cheap fix in the long run. Col
Are you keeping the door open while you lift it?
If the door & windows are shut it creates a vacuum which makes it twice as hard to lift the roof.
thanks Col..could be the answer
Check out RV Airlifters.
Hi Mindi, I stand on the step and unroll the awning a few turns prior to the lift. I have 6 panel on the thing and manage no worries. I am 73.
But I have no health problems. I have read good things regarding the air bag support system but not sure on its longevity.
Retired plumber & Plumberess
 2004 Toyota TD LC
A'van Tayla 17'6" Caravan
Thanks to all for your help. Problem solved. The Jurgens Youtube clip called "Jurgens Poptop" shows their new Easy Up/Easy Down mechanism which they will supply as a kit for about $250 or fit for you for an additional $160. That's my preferred way forward.
https://www.youtube.com/watch?v=7LPzIKubNNE
Have a look on the Caravans Plus website they are $124 a pair so half the price of the Jurgens ones and look to be identical.
