Post Info TOPIC: Towel rack
Towel rack
The double towel rack has become loose in the sliding door of our Jayco Silverline, any suggestions on how to tighten it it would be appreciated.. We cant find a way to even see the screw.
Thanks,
Rosemary
Brian & Rosemary
Check out units (your type) on display at Bunnings the methodology of fixing should be apparent when not attached.
How about a heavy duty Glue.  Maybe one of the Loctites ?
 Have a look under the bottom of the mounting post many have quite small Allen Screw under there you need to undo to release Post from . mounting bracket.
Bliss On Wheels
