SmartBar SmartBar
Post Info TOPIC: ctek battery charger
hi
would any one know if a ctek 10 amp battery charger has a fuse inside it
thanks
Which specific model? The ones I have dismantled have been fused internally. Not hard to look, if the charger is dead and outside warranty period. Just make sure the charger is not plugged into 230 V if you are going to fiddle with it.
Iza
Iza
I don't know if my charger has a fuse in it. But have been happy with the Victron 10 amp charger & it sents to your phone via Bluetooth what it's doing. Also can set it to a low setting of 3 amps if required.
ctek mxs 10    just wondering if  its able to be fixed  as they are not cheap to buy
What's its history of use? If its 10 years old and suddenly stopped working, then that is a reasonable life, disappointing but reasonable.
Iza
Iza
charger is around 4 yrs old  out of warranty now
terrola, I assume there was a leaflet supplied with it. If so, is there a fault finding page?
If it's this one (automotivesuperstore.com.au/ctek-mxs-10) - they sound to be bullet proof. Do you use the temp sensor? If so try shifting it to another location.
And yes, they are EXPENSIVE! I'll stick to my <$100 Repco charger.
Suggested last port of call - ask a dealer.
yes i did move it to another position          thank you for your replies
Hi terrola,
Is it still not charging?
I use a CETEK DC-DC charger on my aux battery & due to the location of the battery, I maladjusted the location of the sensor to get some charge into the battery. If I put it on the +ve terminal where it's supposed to be, I would not get any charge. Batteries are designed to work best at 25 degrees, not 70-90! Risky? Yes, but I have to drive the car in all weathers & here up north, it's warm most of the time.
weather is not the problem here   i took it out of van  tried it on my car battery  same thing not charging      tried taking the screws out to look in side   1 screw  sealed  so you cant pull it apart  was reading cant be fixed in australia      not happy     would never buy ctek again     {rubbish}
Thanks for posting was advised to buy CTEK battery. Will reconsider now
Just to offer another perspective, I have two 15 amp cTek chargers, both have been operating reliably for years, very happy with them.smile
Santa.
i expected to get more than 3-4 years  with very little use   have now bought a                          victron 15 amp charger hope to get a longer life from this one        will see
