Post Info TOPIC: 15 inch jayco sterling rim
Hi All Looking to buy a second spare for out next trip Birdsville way in July Suit 195/15 LT tyre Ideally same as current rims Any help appreciated Send message for contact details
As Jayco regularly change the design of the wheels they use, it may be worth citing year and attaching photograph of the wheel so we can see what design you need.
Regards Ian
G'day Orca,
Welcome to the forum. Mostly you can get lots of good info from the members but your query might be an exception.
Unless you can get a second hand one from a caravan wrecker, the only way is to go to Jayco & they are expensive. I found a split in a spoke on a wheel on my van - the new wheel cost $320. My wheel was a 15x6 JJ & only Jayco can get them (from China). Have a look on the back of your spare & you'll find the info on one spoke. My tyres are a bit bigger than yours (235x75x15).
Also check that the new hub cap will fit if you have to swap wheels later & check the rating (mine are 1000kg, which I think is a bit light on for a single axled van).
The most important thing when going to the Birdsville area is to have good rubber on your tyres & reduce the pressure in them if the road is stoney.
