SmartBar SmartBar
Post Info TOPIC: Thetford C2 Toilet: Red Faced but not Flushed
My caravan toilet, a Thetford C2, worked perfectly when I parked the caravan a few months ago. It now will open the valve but it will not flush. I have checked the flush tank is full, the main tank is empty, the fuse is good and the switch has not been changed. Apart from not using it, is there anything else I should check before I give up and take it to a caravan repair place? Any help appreciated.
Brian
Little Briney
If it isn't on does the water pump need to be turned on or does it have a separate pump that may have seized up ?
-- Edited by Bill B on Wednesday 6th of March 2019 08:52:08 PM
Bill B
More than likely seized pump, can buy them on eBay for
$10>15 each. It sits just below the toilet roll holder which
just pulls up and is held in by one screw.
You can prise the bottom of the pump and with pliers rotate
the shaft back and forwards to free it up as most times it's a
build up of calcium. The bottom should push back on.
This is a bushfix to get you out of trouble
while waiting for a new pump, I know it works as have done
it a few times
darjak
Bill B
It has a separate pump. You are most likely right. It is probably seized up from non-use.
Thanks, I'll check it out.
Little Briney
Darjak
Thanks very much. I suspect you are spot on. I will try your bushfix in the morning and order a new pump.
You're a life saver. I'll let you know how the bushfix goes.
Little Briney
Morning Darjak
Got the toilet roll holder out and pulled at the pump but unable to remove the base or free anything up. I'm not confident to use force so I'll let a professional look at it. I'll let you know how that goes.
Thanks very much for your advice. It is very much appreciated.
Little Briney
Sorry to take so long to get back with the results. Darjak you were right. The immersible pump had frozen. It has been replaced and is now working perfectly. Thanks once again for the advice.
Little Briney
