SmartBar
Post Info TOPIC: Running fridge from tug via Anderson plug not working.
Bought my van 2nd hand and it ran the fridge on 12V only when connected to the Anderson plug
on my tug. Now it wont ! I have had a CTEK DC/DC battery charger fitted to the tug and I am wondering
if this may be the problem. Would appreciate any feedback !
Fridge is not connected to run off van battery
Duncan.
Fridge may have a low voltage automatic cut out. So firstly check the the fridge hand book for voltage cutout and then check voltage to the fridge at the fridge end not the battery.
Check that your Anderson plug is still connected to 12volt from the car. It may have been disconnected when the ctek charger was wired in.
Where is the anderson battery getting its power from, is it the spare battery in the car that you now charge with the ctek ?
I am assuming your fridge is an compressor type fridge ( 3 way fridges use a lot of power on 12 volts )
Perhaps a little more information on the fridge and your battery set up would help...you did say the fridge isn't connected to the van batt ( is the van batt connected to the ctek charger and not the car as I assumed )
check your Anderson plug fuse / breaker and batt connection.
Leshill
Also check voltage at plug .
Suggest you go back to whoever installed the CTEK and get them to fix it since the installation appears to have been the cause of the problem.
Just a query, you had the fridge running off the 12v supply from your tow vehicle, and everything was fine, then you had a DC/DC charger fitted to the vehicle. So do you run the fridge via an aux battery fitted to the tow vehicle, have you just had an aux battery fitted to your vehicle, and previous was the fridge wired directly to the vehicle start battery, or is the dc/dc charger wired to charge the caravan house batteries from the tow vehicle and the fridge is still charged from the tow vehicle.
