Post Info TOPIC: Exterior light replacement lens
Does anyone know where you can get replacement lenses or led replacements for 225mm square external caravan lights? Mine have yellowed and are so brittle they cracked when I took one off. They would be 10 years old. I have not been able to source them from any caravan store.
This is the light cover I need.
Evil bay have many around the $20 mark www.ebay.com.au/sch/i.html
Have a look also at the RTM (Road Track Marine) catalogue
If you find one or the complete unit can you let the Forum know, as I have one on the drivers side of our van. Have 2 spares ( offwhite and pre owned)
The problem with our light is the big cut out in the van wall, so to replace it you would need to cover the hole with a plate and mount a smaller fitting onto the plate.
My caravan repair people cojuld not source one. They installed a small strip of led lighting and you wouldn't know it was a replacement
Greg
Get two at a time . They last about 18 months 2 years in sun . Yes eBay .
There is no good just saying eBay, you need to give a direct link to the item you are referring to. I can't find it on eBay and Possum's link does not produce the required result. If you are going to give a recommendation for the source you should check that they are available there and when you are checking you will have a link that you can post.
Thanks.  I agree a link would be handy as I could not find anything on eBay and as they cut a dirty great big hole in the van paneling to install these I need a big light to cover it.... damned annoying confuse.
Thanks Possum 3 but they are not the size I need. I have a hole 110 x 110 to cover and I can find nothing this size.
have you had any luck finding these lenses ? (i need some ) the people at cara rest s.a. told me they are no longer available i am thinking of bleaching mine with peroxide cheers kevin
