Post Info TOPIC: Replacement HWS
Replacement HWS
Hi All,
While away last week the tank in our Suburban HWS began leaking. Not sure how old it is but apparently the tank is made of aluminium and has corroded where the cold water pipe goes into the tank. By corroded there is white powder all around the pipe inlet and water just pours out.
There are two things about this problem. One, the tank is not separate and the entire unit has to be replaced. And two, there is no shut off tap going into the tank that I could find so the water had to be turned off at the outside standpipe. Apart from having to carry jugs of water from the outside tap for two weeks, my wife wasn't happy about not being able to use the on board toilet at night - no water to flush it!
Go ahead and laugh, you free campers!
Anyway, I am resigned to buying a complete unit. Is it possible to install one of these systems myself, or is it so specialised that a plumber has to be engaged for their large fee?
Murray
Flush the toilet with a jug of water
If it is gas + 240v you will need a gas fitter/ electrian , it needs to be certified to be legal
blaze
The tank of your Suburban is steel not aluminium. The white you are seeing is the sacrificial anode that is there to prevent the tank from corroding away. It should have been replaced approximately once per year.
You can do all the replacement work yourself except for the gas and 240V connections which should only take a few minutes each.
Should be a pretty easy job replacing like for like. If you get stuck take it out to Pharleys at Hume & have a look at 'Caravans plus" at QBN re purchase & change your anode at least once a year, but you probably already know all that.
Easy to do ie remove old and slide in new, but as said need 240v plug attached and gas econnected and leak tested
I could give some advice but not without receiving a large fee....smile
Retired plumber & Plumberess
 2004 Toyota TD LC
A'van Tayla 17'6" Caravan
 I gave it for freeeeee  lol
Thanks for the replies.
I bought the van from a Jayco dealer 14-months ago, assumed the anode would have been checked then I upgraded from a Freedom that didn't have a HWS or en suite so it took a while to ease into it. As a matter of fact we didn't start using the HWS and en suite until the middle of last winter.
I thought that anodes lasted 12-months, and as we had only been using the HWS for around 6-months, should have been within the limits. But someone has just told me the anodes degrade whether the HWS is used or not. That would be a problem for vans in storage for eleven months of the year and used for the Christmas holidays.
We have made eight trips in the van in 14-months travelling a smidgin over 5,000-kilometres.
Anyway, the tank looks like it was aluminium, particularly with the white powder around the inlet. I would have thought that the tanks would be available separately,
As far as doing the job myself I expect that there would be a plug for the electricity - just like a microwave. If it is hard wired in then it looks like I'll have to engage a professional. As far as the gas goes, well, everyone has had to change over cylinders regularly, don't they?
Actually, I thought the biggest problem will be all the pipes going every which way in the vicinity of the HWS. Maybe it will sort itself out once I get going.
I expect that the new HWS would have complete instructions with it.
By the way, I know about using a bucket to flush toilets - we have had our house cistern fail from time to time. The trick is to use just the right amount of water, tip it in with the right flow. Too much water and too fast results in overflow! But it didn't seem worth it - after all, every time the toilet was 'flushed' someone!? would have to go outside to fill the bucket up again anyway.
Murray
seems you already had all your own answer anyway
blaze
blaze
 Certainly seems to be the case.confuse
Santa.
Murray
Sent you a PM ref this. Cheers baz
Rather than replace like with like, have you considered the new instantaneous hot water systems. I saw on in one of the online magazines recently. Not sure if it was Unsealed or RV daily or something similar. They are not 240V but use a lot less gas as they only heat up when you turn on the tap. They are designed to fit into the space of the Suburban unit.
Wally
16.5 Discovery 4 with a few mods and New Age MR 16' Deluxe
Wally
 Most, if not all demand gas heaters are enormously gas hungry Wally, I speak from experience.smile
Santa.
Santa wrote:
Wally
Yep we try to save $ with all sorts of batteries, solar and inverters and numerous gadgets and fit other that cost more $. ??????? Why
