Post Info TOPIC: fridge / freezer protectors
We run 2 engels ( 1 as freezer, other fridge ) both within those insulated travel bags.....great......NO, the other day i needed to pull the freezer one out of the vehicle, all good, once out i removed "the bag". the freezer was swimming in wet condensation on all sides, the water was trapped between the bag and the freezer, for how long i don't know, but surface rust was developing as a consequence........BEWARE
If you aim for nothing.....you'll hit it every time.
A sure sign the fridges insulation is very poor & high humidity. Especialy if you use them as freezers the foam insulation can also become water loged. Pulled a Waeco apart that had been used as a freezer for a long period of time, & the foam insulation was full of water like a spounge.
D.L.Bishop
Is the fridge using polyurethane foam? It has a shorter term insulation advantage over styrene. In the long run styrene maintains a better R value due to less moisture getting into the foam.
This seems to be a common problem in tropical areas.We leave ours off all the time now. No more sweating or harbour for bloody ants and their eggs.
spoke to engel australia, the fix.....remove bag and wipe case as required. So there you have it..Grrrrr
