Post Info TOPIC: Incomplete/Inadequate Program Menus on VAST Satellite TV..
Has any one else experienced incomplete/inadequate program Menu information on their VAST <Viewer Access Satellite Television> in recent times?...
It may be my reception/set up, however the majority of my Vast menu now states "No Information'.....previously there was complete descriptions of the program being watched and those
programs to follow....now its pathetic menu "service" on many levels.....are the respective TV Stations not providing the information as they did previously?......may be a simple
explanation.....any ideas?..thanks.  Hoo Roo
Hi Goldfinger;
                   This problem sounds like digital drop out, and can be caused by if your dish is off direction , the LMB may also be off ( try turning it and peaking with your sat meter if you have one ) also have a look at the coax cable and check all of your connection are in good order and your cable is not damaged.
You can have this type of problems with your reception when you have this sort of problems.
