Post Info TOPIC: Anti Theft System Alarms and Trackers
Anti Theft System Alarms and Trackers what can u recommend without breaking the bank.
We would like a Alarm for breaking into the van and Tracking device for steeling the van can u buy a all in one system?
Thank you
Tracey
Lots of systems available to buy.
Physical things like wheel clamps/trailer hitch locks  etc. For the Caravan.
OBD trackers for the tug from around $40 on Ebay or some dedicated units that are in the low hundreds that are both alarms and trackers.
I have an old phone with a Data only sim that uses the GPS function as a tracker costs $5 pm from most of the big Telcos.
This is an Aussie company.
Does the lot.
http://www.findandfollow.com.au/caravancampervan-tracking-solution/
Tracey, some info Here:
caravanersforum.com/viewtopic.php
I previously had a 2G version similar to the item below which I think is a 3G version but you need to check, also confirm that it will work on Telstra Frequencies.
I purchased that 3G/4G tracker mentioned in the CP Thread above because it works on the Telstra Network and it has more 3G/4G frequency capability that any other Tracker I have come across.
www.ebay.com.au/itm/Vehicle-Car-GPS-Tracker-Class-GPRS-GSM-SMS-TK103A-Tracking-Device-Alarm-System/382352570134%3D777003%26algo%3DDISCL.MBE%26ao%3D1%26asc%3D20140117125611%26meid%3D6226e689e6cf4b029cdf271f9317be7d%26pid%3D100009%26rk%3D1%26rkt%3D10%26sd%3D223192814874%26itm%3D382352570134&_trksid=p2047675.c100009.m1982
