SmartBar SmartBar
Post Info TOPIC: Dometic 350W inverter testing
Hi all,
I've been fighting the purchase of a 240v inverter for some time in either the pajero or the caravan.
Whilst I'd love a lithium set up, the cost far outway my current requirements. If I hit powerball, that will of course change pretty quickly biggrin
To that end, I've been focused on making sure everything I had was 12v compatible to allow me to make the most of my battery set ups.
Unfortunately that run has come to an end and I've had to pick up a small inverter for some gear that I can't get or don't want to get in 12v form.
The primary reason is for charging 18v batteries for my recently acquired chainsaw.
On sussing out online forums the consensus seemed to be a 300w inverter should be sufficient for charging up 18v batteries on the go .
I set that as a limit, as I didn't want to get anything bigger than I needed from either a money perspective or size.
Overkill can be good but again I was focused on just meeting my minimal needs and no more.
Of course, as we all do, I checked out the cheap ebay options and in the end avoided those when the known brand Dometic popped up for not much more at Snowys. (no affiliation)
Since I was heading away and needed it sooner, I found it local at BCF and they matched the price (usually $199) and I was able to pick it up same day. Plus, I have local support if it craps itself. That's always nice :)
Making sure it was going to cover my requirements and to see what sort of load it would put on my batteries, I wanted to run some tests so I'm across what real world usage looks like instead of just relying on website guff and stickers.
I've been very happy with the outcome.
Both 18v battery chargers are rated under 80w z(72 & 78) and came pretty close to it during testing.
Obviously there are losses involved but my testing at the battery showed these to be minimal with just over 80w being pulled.
Granted the power supply I had was outputting ~13.8V but I am most likely to charge up my batteries either on the go or when the solar panels are taking up the load, so the inverter should be seeing around this voltage anyway.
So I feel this was a realistic test.
If only running off a charged AGM, voltage would be closer to 12.8 and the current would come up a little to meet that 80w required.
I'm considering a double battery charger which would be handled no problems.
During my tests, 6amps was around the average requirement.
This was the same for both the toolpro and ozito 18v chargers
and the DJI spark charger was slightly under that.
The inverter fan comes on at intervals and can be quite annoying cutting in and out.
So for night time use in a van or the like, probably would get old pretty quick.
In the back of the car or day time use would be ideal.
I do like the layout of this inverter with the plug on top rather than on the end.
This will allow me to mount it upright and have the plug readily accessible.
Probably not handy if you're sticking it under a seat or need access from the end.
Overall a well put together piece of kit at what I think is a good price considering what the no name stuff is worth.
As much as I like to read forums for info, I always like to do my own tests to see if that info is actually correct.
In the end I didn't need anywhere near the 300w suggested but the extra will allow me to have confidence that it is handling the job easily.
The unit is a 350w with a peak at 700w.
Maybe this will help others looking at their options.
As always here's the video of the tests and kinda review.
cheers Brett
G'day Brett.
Nice set of toys you have there.
I have a 300w Inverter I picked up from that auto mob that think they are super. It charges my laptop,runs a 240v fan, charged a beard trimmer, 18v battery for my drill and my 36v battery for my line trimmer, all works OK.
ha, cheers Dougie
Funnily enough, I was eying off my electric razor thinking I could stick that in for those longer trips too now.
Albeit that I like to get a bit scruffy whilst away and use it as an excuse to have a beard even if for a short while :)
maybe I could tape it to a back scratcher and trim up the back whilst on summer holiday, when I don't have a need for my 'winter coat'
I didn't think to try the lap top out of curiosity but have a 12v charger for that. I'm pretty sure the little inverter is going to be enough for anything like that I need to run off it.
It's small enough to be tucked away somewhere when it's not needed.
Gidday Brett,
I have a Giandel 300w inverter which I fitted in my van. It's been there for two years performing faultlessly. Fitted the same model in a friend's van 15 months ago. No problems for them either. Neither of us would like to travel without our inverters which we find invaluable sometimes when free camping.
If you want to save a few dollars, I can highly recommend this inverter.
Flea Bay link below.
Roy.
www.ebay.com.au/itm/GIANDEL-Pure-Sine-Wave-Power-Inverter-300W-600W-12VDC-240VAC-CARAVAN-BOAT/331279407166~1Z9sGT:rk:2:pf:0
Thanks Roy.
Funnily enough, someone on another forum pointed me to the same brand and said they had success with theirs.
I also like the 2 outlets on that one
I was considering a second to save me swapping it from the car to van and making it a permanent install.
With that in mind, 70 bucks is better than 120.
If everyone seems happy with them, could be a safe investment.
Might be a good excuse for a comparo too.
cheers Brett
INVERT.1.JPGI also have a Giandel pure sine wave 600W inverter was about $85 delivered. It works quite well & certainly will handle 600watts load. The wiring supplied is a bit poor for those sorts of loads.
D.L.Bishop
curious why these giandels are popping up all over the place .
Did you guys buy these on price alone or is there some general consensus that this brand has a good reputation or something that I've missed ?
They seem to be quite popular .
cheers Brett
I went on price & reliability from other owners on other forums. After trying one ( and opening it up to see how well it was made) purchased a second one for another project.
-- Edited by DeBe on Wednesday 14th of November 2018 08:18:26 PM
-- Edited by DeBe on Wednesday 14th of November 2018 09:19:15 PM
D.L.Bishop
Thanks DeBe. that's the info I was after.
