Post Info TOPIC: Betoota Birdsville Windorah
hi all planning a trip next year in cooler times say from Windorah to Birdsville via Betoota. I want to know 20 foot van with high clearance van what prep do I need to do? Ive onlh taken on a little bit of dirt bugga all to be honest. Just want as many tips as possible.
-- Edited by fiddlestix on Tuesday 30th of October 2018 05:29:49 PM
Hi fiddlestix, 20 ft high clearance seems exceptionally high. Is that correct?
Rockwood 5th wheeler & Iveco Tug
Ive edited
Those roads can be stony, and they can damage fittings and tyres.
Protect stuff under the van and the tug rear window, lower tyre pressures and lower speeds and you will be fine.
The stone damage on those roads is no worse than the flying stones you get on a lot of roadworks. High clearance is not required, you are not going off road, you are travelling on reasonable gravel roads. There are plenty of European vans that go out there and they do it without grounding the chassis I see no reason to lower tyre pressures on that road either, You should not exceed 70 km/h or so with reduced tyre pressures, there is a lot of that road where you can travel at up around 90 km/h.
I think some members get a bit precious about travelling those formed gravel roads. I have lived a lot of my life where the roads we travelled were similar to that. The people out there just treat them like suburban roads. You have to look ahead for changes of road conditions on both and slow down if you are not assured of continuing perfect road.
Just go out and enjoy your trip. There is perhaps one little section of road to be especially careful on. Leon's Lookout is a good rest stop with a dunny. It has a good outlook over the plains from a high elevation. If you want to use it then slow to about 20 km/h and you should survive the side trip without damage.
-- Edited by PeterD on Wednesday 31st of October 2018 11:32:56 AM
We took our motorhome there last year and went VERY SLOWLY and had no problems at all. The road was horrible in some places but I repeat we went VERY SLOWLY and that is the secret. Let them roar past you at 100 k's an hour. Who cares. Enjoy the trip. We did
I agree with Peter D about not needing high clearance.
These pics were taken between Hadden Corner and Betoota in 2012. Nothing would have changed much since.
Hi fiddlestix,
Just have good rubber all round & take the advice of PeterD & Peter_n_Margaret.
The stones out there are hard & often sharp (jasper). In 1976, I blew a tyre near Betoota & had the unfortunate situation where the car slipped off the jack. I must have "found" a less rocky area as it took a lot of effort to find some rocks to use to lift the car again!
Just be wary that the roads out there can change from year to year, depending on rain & the amount of traffic. Contact the Police at Birdsville if you have any worries.
PnM, I've been enjoying your pictures of recent days - your truck is one in a million!
 Thanks. The one above is a friend's.
G'day mate
We did the Windorah to Birdsville & back again in August this year - timed between the Big Red Bash & the Races so the town was quiet - only regulars + 100 or so visitors, rather than the 10,000 to 12,000 who arrived for the other 2 events
Regular road maintenance was underway towards the Birdsville end, but overall, the 275km of gravel road was "pretty typical of many other outback roads we've covered". Our road speed varied from 60km/h to 80km/h with 90km/h in places, and before we started I dropped tyre pressures by 1/4 from the vehicle's highway 60 psi pressures
Both Windorah & Birdsville are "2 streets wide x 2 streets high" with limited / typical outback services, food is plentiful, tho selection limited & Birdsville has a beaut hardware store for all sorts of 'spares'
Here's some pics of that part of the country
1) The road ... pick anywhere to minimise the bumps & move back to your side when someone's coming
2) One of many roadside stops
3) The best place to overnight - Deon's Lookout
4) An amazing artwork made from thousands of coloured stones & goes around the whole hill
Hope this helps
Phil
-- Edited by Ozzie_Traveller on Thursday 1st of November 2018 10:19:08 AM
Last time I travelled that road, they'd put a lot of that horrible black stuff on it.
Seeing you have a Jayco just make sure you warp your drain pipes,the hardware
at Birdsville makes a good living selling it.
darjak
