Post Info TOPIC: LOOOOONG POWER LEAD
LOOOOONG POWER LEAD
Morn'n all, hope all are well on this well, overcast coolish day here in down town Young NSW, anyway. Yep, still here.
Just after your thoughts on running a 15amp lead via an Amphibian 10 - 15amp, from a power supply approximately 60mts to a van. Power loss etc confuse
I am pretty sure I know what is coming my way in the way of replies crysmile
Have a good one everyone.
I would be moving the tepee closer if possible in any way - otherwise using another power source ie. solar or generator.
yeah, good luck with that one Doug
www.safework.sa.gov.au/sites/g/files/net4331/f/3.18.14.1-buildingconstructionindustryguideline-electrical.pdf
See page 13.
To get a 60m long 15A extension lead, the conductors must be 6mm2.
I have a 4mm2 extension lead that is 30m long. The cable cost about $100, so you will be up for at least double that I reckon, plus plug fitting.
Ho hum... I might do it in particular circumstances but I'd advise you not to.
Not least is the problem of different earth potentials between the earth your caravan may find through its legs et al to the earth from the supply point.
Also 60m is a *long* way to run an extension cable and be sure no one is going to drive over it or lawnmower it or whatever - they are not intended for runs of that length.
Doug Another thing to consider you will not be drawing 15amps due to the amphibian and also no doubt you will very aware of your situation and be very conservative in current consumption also Mike brings up a good point abt the usefulness. Of the earth over that distance
Thankyou all for your replies.
They are exactly what my thoughts were. It was a happy hour discussion last night to try and get family and visitors that bring their CV with them to stay for a while in a different spot. My mate and I were saying how it takes up a bit of parking space around the house so had 3 options.
I ruled option 1 out early today due to steep slope but had close power and bore water supply. The second was needing a 60mt approx, lead run from power supply and also on a slope. I reckon once the van was levelled there would be at least 1mt clearance at one end with both option 1&2. Way too much for my liking, anyway. Option 3 is level and near bore water supply but no power.
I have no problem as I have heaps of solar and battery power. I also can fill my 200lt tanks with tank water from the farm (it is a massive tank and full) and top up when needed as would other visitors.
Both of us will check it out together again tomorrow as he is away today.
There is no legal problem with having and using a 60m 15A extension cord that I can see.
It is simply a matter of cost and looking after it.
I agree Peter. I have read nothing either to say it is 'illegal'. Option's 1&2&3 have no safety problems either as cars etc don't need to go in those areas near leads once set up and grass cutting would take place prior to any arrivals. It's just the big slope that concerns me more than anything else. My mate has mentioned he could get the tractor out and level a spot but I don't think it's needed as option 3 is fine by me.
I have plenty of Solar and a 20i Generator so power supply is not a problem for me and I'm sure others will be fine too. Still, a good project tomorrow.
-- Edited by Dougwe on Thursday 4th of October 2018 02:58:54 PM
As long as it's not for an airconditioner why not! Fridge and lights at night will only be less than 5 amps so there would be minimal voltage drop. Suck it and see I reckon. Many people have done stick welding at the end of a 20m 15amp lead and this draws a full 15amps when striking an arc.
Good Luck.
Good Luck.
 IF it is a single length,  as required under the Standards, using 4Mm Sq cable, current & voltage drop, unless using an air cond, should not be a problem.
With one exception, that being the one raised by Mike, possible "earth voltages" resulting in ground currents overheating "cable earthing conductor " especially if the ground is damp.
Or, if the van feet are not in direct contact with the ground, a voltage difference between the van & ground, perhaps giving a slight shock, when touching both van & ground
-- Edited by oldtrack123 on Thursday 4th of October 2018 04:27:58 PM
Earth is an issue if theres a fault in the first place !! Assume theres a safety device ? At van . Dreaded VD over that distance !!
 An RCD will not detect that sort of problem
One thing I didn't mention and has been mentioned above is it will be 2 leads joined and aircon will more than likely need running.It's not gunna happen!
 for aircon, ya better join 3 leads doug biggrinbiggrin
blaze
Makes sense to me Blaze. Three leads...three times the power smile
Shocking idea Doug!
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
I thought I was a bit of a bright spark really but never mind.
All sorted. The teepee is set up in a lovely spot with late afternoon shade but full sun during the day. Power is coming from the solar panels and batteries and water is hooked up to van via a tap connected to nice clear bore water via two BEST filters before entering van. Fridge is running on gas.
No need for long or short leads at all.
I now have neighbours up the hill (friends) and I will go to their place for happy hours biggrin
