SmartBar SmartBar
Post Info TOPIC: Plastimo water bladder
Mez
Hi, we have purchased an 150l Plastimo water bladder for extended stay in free camping, as anyone purchase the same brand ? can you please let us know how you manage to fit a pipe in the large fitting , we are having issue finding reducer to fit the thread that is on the bladder , if anyone has one of them can you please let us know who do you fill them up. thanking you- Safe travel Mez plastimo-water-tank-flexible.jpg
Mez & Christian
Have you tried Bunnings or an irrigation supplies ?? Cheers. Col
Mez
yes we have Col, but the thread is different to ll the one we have looked at so far, may be because it is made in France ?? thanks you Mez
Mez & Christian
Contact the person you bought it from ??  Maybe a lesson to others to check where manufactured and if parts are available.
Their website shows the inlet to be 38 mm. Their fittings page shows the 12 mm hose fitting to be 3/8" and the 38 mm hose fitting to be 1 1/2" - these could be British Standard Pipe or National pipe thread dimension threads. You can use those tables to sort out what they have used.
There is a distributor you could try at Ormeau.
AMI Marine Queensland
Unit 1, Hopper Avenue
QLD 4208 Ormeau
Phone : (07) 5540 6800
Fax : (07) 5546 7044
Website : www.amisales.com.au
I don't use the big connection on mine, I blanked it off and just use the small one to fill and empty the bladder.
Mez
Thank you all for your replies.
Peter , we did find the same distributor in Sydney after looking up on their website ( we are in NSW), worth a phone call and in the meantime we will try John's your suggestion , my husband was also thinking of replacing the big connection by another small one .
Hopefully it will work.
Mez & Christian
Mez & Christian
