Post Info TOPIC: HELP please 12 volt system
Is there anyone in or near Barcaldine Qld that has some 12 volt know how and ability? Our house system on the motor home died last night batteries are good individual fuses are good. Exhausted my small level of knowledge and ability. Thanks in advance
You can't get lost, if you don't care where you are going.
Have you asked anyone around the park if they can assist?
You could also detail what is happening. How do you know your batteries are OK? Is there anything working at all?
Hi Peter, yes I have asked around batteries are fine via solar controller and multi meter as I said I have exhausted my knowledge and need somebody to check it out
HI
Voltage tests
volts on
full sun to solar
In side of solar controller [from panels ]
Out side of s/controller to battery
Amperage tests same IN and OUT of s/controller
Does the system have a on/off isolator ??
Does the system have a low volt disconnect ??
checked all your circuit breakers ? Did the loss happen slowly or all or a sudden ?
