SmartBar Camp Creative
Post Info TOPIC: DC-DC Charger blowing ignition feed fuse.
Had a Projecta 25amp DC-DC charger fitted to caravan.
Solar input works fine, but the ignition feed keeps blowing the 30 amp fuse.
Output from the Alternator is 14.2 volts.
Kevin Kyle
On the road full time with Son and 21 year old cat and 3 year old Manx.
Toyota Landcruiser 100 series V8.  Nextgen semi off-roader.  3 120 AH agm batteries, 1KW Solar
straight back to the installer something is not right ! my alternator can run up to 14.7 to 14.8 v at times and never had a problem, same projecta dc - dc charger as you .
 No surpises here, bloke that installed it has ****ed everything he has touched.
Kevin Kyle
Is the ignition circuit taking the full load ? Amps ??
 In the van wiring?
Blowing fuse 30 amp. in the van.  Car wiring checked by Autospark and all good.
Kevin Kyle
Should the charger be connected to or through ignition directly in the first place ? Imo it should be through accessories or relay ? Double check what DC -DC recoment . On EFI or electronic ignition they should be seperate . Check wiring diagram. Adding load here is overloading circuit !!
Is your vehicle equipped with ecu controlled voltage reg ?
 Alternator power is controlled by relay, not Redarc, but similar, also used to charge Ark battery box in the car, off same circuit.  It also has 30 amp fuse with no problems.  Is wired as per the circuit diagram in the Projecta manual.
Kevin Kyle
Ok just thought the ignition wire was only for smart - ECU controlled alternator ??
https://www.autoelec.com.au/projecta-12v-volt-dc-to-dc-25a-amp-battery-charger
 Thanks AK, yes I have double checked with with the bloke that did the car installation, the car installation is correct.
I have looked at the cable the van installer has used and it appears to be as per the manual.  The cable that is used for smart alternator appear to have been removed and the red ignition cable is the one connected via Anderson plug to the alternator.
Kevin Kyle
I note that the input fuse raring (rating, bit old to be raring fusesblankstare) is 50w
-- Edited by Snippy on Wednesday 29th of August 2018 12:57:38 PM
Kevin Kyle
Hi all, Thanks for your input.
I have just spoken with Projecta tech support, (Brown and Watson).
The ignition feed fuse should be 50amp circuit breaker. The installer has has used a 30 amp inline fuse on 30amp cable.
I am tempted to name the idiot installer, but softly softly for now.
Kevin Kyle
 good call I think.
I have the ID25 in my pajero and I'm pretty sure the instructions called for a 30amp breaker/fuse.
I checked the online install instructions and it says 50amp.
So I'm thinking it may have changed at some point and he may very well have followed the older instruction.
That being said, I used a 30amp and had no issues with it tripping or causing any issues.
Not sure if that helps any biggrin
Snippy,
Just be aware that there are two types of cct breakers - auto-resetting & manual resetting - the latter gives you better control of any fault.
I have seen a disastrous issue with an auto where the people involved weren't aware of a problem until they stopped & saw smoke!
Snippy wrote:
 In the van wiring?
 There is no need for a fuse in the van. I would only put a fuse near the battery supplying the load. In this case the battery is in the tug. A fuse at the input to the charger will not protect the charger. Thay do not make readily available fuses that act that quickly. The only fuse that is necessary is the one that will blow if there is a fault in the supply cable. Every fuse you have in line increases the voltage drop a smidgen. I would be inclined to remove the one in the van. The one in the tug should be rated at 50 A.
Yep . Assuming cable / wire is heavy enough ?
denmonkey wrote:
 good call I think.
 The manual he was given said 50w.  The bloke is a cowboy.  RV Builder in Beaudesert(Ooops slipped out)
Kevin Kyle
PeterD wrote:
Snippy wrote:
 In the van wiring?
 No Peter, the battery is NOT in the tug.  The manufacturer clearly states that the 50amp circuit breaker must be in the van in the ignition feed cable.  I spoke to tech support as above and that was their instruction.  THe manual also clearly states this.
To put it simply, rip off unqualified installer.
Kevin Kyle
HI
Alternator/ battery feed =50amp fuse
Ignition override sense wire [to remotely turn unit on/off ] fused 1-2 amps
swamp wrote:
HI
 Hi Swamp, yes as per the manual, too easy, well for most of us.
Kevin Kyle
FWIW... not an uncommon mistake to make and might not cause an issue for most, that is using a 30 amp fuse for a 25amp DC2DC charger.
If your voltage drop leading to the charger is small, you may not have an issue (such as an under bonnet dc2dc fed with a meter or two of 10mm plus cable). But with one in a van hanging off 10-12m of cable, there will be a bit more voltage drop across the cable feeding it, so the dc2dc charger will need to draw more current to produce it's output voltage and current.... I tend to go at least 40a on a 25a unit.
Also worth having a fuse protecting the van cable near its inlet plug.....  some day the van may be plugged into a vehicle wired with, say 25mm plus cable and fused at  a much higher amperage.
-- Edited by Noelpolar on Friday 31st of August 2018 09:30:52 AM
-- Edited by Noelpolar on Friday 31st of August 2018 09:38:18 AM
-- Edited by Noelpolar on Friday 31st of August 2018 09:38:47 AM
Jayco Silverline Toyota 200
This is basically a repeat of what has already been posted but for some reason this post got stuck in the pipeline when I shut my computer down yesterday afternoon.
The most common problem we have when it comes to DC to DC chargers is the installer using an under rated fuse or poor fuse/holder design or using a circuit breaker rather than a fuse. 6 B&S cable can handle a 100 amp load without melting or catching on fire so what is the logic in fitting a 30 amp fuse? A fuse is only there to protect the cable run, not the appliance, if the appliance has a fire risk in the case of a short circuit it has its own internal fuses rated to protect against that problem so adding an under rated fuse/circuit breaker in the supply end of the cable is just dumb. It seems many installers have forgotten ohms law when it comes to cable size requirement and fuse rating. If the DC to DC charger can produce 25 amps @ 14.4v the output is 360w. Add 10% for conversion losses within the equipment and the requirement on the input side is up around 400W. If the unit will function at a voltage as low as 9v say, then 400w divided by 9v = approx. 45 amps. That is the current required at the supply end on a continuous basis, a 30 amp fuse or circuit breaker isn't going to meet that requirement, even a 50 amp fuse is getting close to its limit and a 50 amp circuit breaker of the type often used by installers for DC circuits most certainly won't handle the heat generated through the bi-metal strip on a long term basis. Now add the arcing across the contacts each time it trips and resets increasing the resistance and the once rated 50 amp circuit breaker drops to 30 amps or less after 15 mins and useless for the job.
A 60 amp midi fuse and holder will minimise the poor connection heat generated by many fuse/holder types and have enough overhead capacity to prevent nuisance failures, yet well within the safety limits of the cable it is designed to protect.
T1 Terry
T1 Terry
 I could not agree morebiggrin
Follow Terry's advicesmile
Just make sure ,that at no point ,are supply cables   rated lower than the fuse
-- Edited by oldtrack123 on Friday 31st of August 2018 04:24:28 PM
T1 Terry, Exactly what the guy at Jaycar said today and has supplied the circuit breaker (60 amp) and 50 amp cable to complete the connection.
Thanks everyone for your input. Will hook it up tomorrow and let you now how it all goes.
Kevin Kyle
Correct me if I am wrong . Itâs blowing ignition feed fuse . Is the standard wireing being used ? I highly doubt it would be 50 amp rated . Is it using this circuit to trip relay ?
Snippy wrote:
PeterD wrote:
Snippy wrote:
 In the van wiring?
 When I said "I would only put a fuse near the battery supplying the load. In this case the battery is in the tug" I was referring to the battery supplying the power to the charger. That is in the tug and should be charged by the alternator when the DC-DC charger is operating.
The underlying principle of good circuit design is to keep the number of fuses to a minimum. Having two fuses in the one circuit that connects a battery with a load is pure stupidity. The one fuse shouild be close to the voltage source, ie the battery. (However, if there is a battery at each end of the line you should have a fuse at each battery.) This principal has applied over the 50 plus years I have been dealing with electrics. Putting a second fuse in line causes confusion when people are diagnosing problems, they do not expect extraneous fuses to be in line. Handbooks dealing with devices like this often picture a fuse at the input to the device, it is put there to remind people that a fuse is required between the battery and the device and not that two fuses are required.
Except starter motors . Cable is sufficient!! Lol mind you fuse is a great isolation device ..
Hi Peter,
Yes it is the second battery the one in the van that has the wrong fuse.
Projecta tech support bloke  said this needs to be 50 watt amp circuit breaker, not 30 amp.
There is no issue with the tug end of things, just the connection in the van. There is a fuse at each battery.
Kevin Kyle
