Post Info TOPIC: No weld Jockey wheel broacket
Hi all im after a no weld bolt on jockey wheel bracket to bolt to the inside of my A frame my A frame is 125mmx50mm. My current jockey wheel holder is welded on from new but it doesn't allow me to put my WDH on. So basically looking at options to make life easier with out welding.
TIA
Same answer as when you asked last week re trail a mate . Go to a trailer parts place with your measurements and they will sort you out.
This is probably what you are after;
https://www.caravansplus.com.au/ark-jockey-wheel-clamp-eight-hole-bolt-on-fcl8-p-12999.html
Note that you have to provide your own 'U' bolts - make sure they are 12mm/half inch plus lock nuts and washers. Actually, you can buy the 'U' bolts from the same shop.
Murray
-- Edited by Long Weekend on Thursday 26th of July 2018 12:55:49 PM
Any boating/camping shop will have them, take your pick.
www.bcf.com.au/boating/trailer/jockey-wheels
Cheers Keith & Judy
You can weld most brackets to your chassis like the one from BCF attached:
\https://www.bcf.com.au/ark-fixed-bracket-jockey-wheel-clamp/6863.html
