Post Info TOPIC: 3 way fridge problem
Hi there, help needed.
Have a Jayco Silverline and only recently the fridge will not run on gas or 12 volt.  Gas getting to stove and hot water fine.  Travelling very soon, any help much appreciated to solve the problem.  Battery went flat recently so changed that.
Is it trying to ignite? Some times it takes a while for the gas to get there . Ahh 3 way fridges !!
is there a gas tap under the fridge?
Jenny and Barry
Click on SEARCH & then type in 3WAY FRIDGE, you'll find a world of pain & suffering.
Cheers Keith & Judy
I agree 3-way fridges have limitations. However, after 10 years travelling full-time with my Dometic 3-way I have found none of the problems that some seem to suffer - excepting extended times in 35+deg temps. I would be certain there are other happy owners and users of 3-way fridges.
Perhaps it is a bit like all 'appliances/vehicles/vans/houses' ... depends on the luck of the draw.
The OP is not whinging about the general performance of their 3-way fridge but rather that ".....recently the fridge will not run on gas or 12 volt...."
One would normally assume such a comment would elicit responses of assistance and advice rather than trotting out the over-hyped and far too often denigration of 3-way fridges.
As a first step get someone to check if there's a spark (where the gas gets lit) whilst you're inside clicking.  If there isn't then check fuses.
Welcome to the gang creena, enjoy here and out in the playground.
Shouldn't need a spark to run on 12 volt it is an electric heater (Not gas). - Does the fridge work on 240 volt? As Moose said check fuses if not blown I would say the heating element is blown. Also do the dumbo thing Turn it off and on again to ensure it's on.
 Unfortunately they have a bad track record on all RV forums. A new Dometic 90lt 3 way fridge costs around $850, we've spent over$1,000 getting ours repaired on 4 separate occasions.
We've met a lot of people on our travels with the same experiences as us. Weight of numbers & evidence give a true picture. End of story.
Hopefully the OP gets their fridge going without spending what some of us have had to.
-- Edited by Desert Dweller on Thursday 19th of July 2018 04:04:33 PM
Cheers Keith & Judy
Maybe take it to a reputable repairer & have it checked. That would be my solution as I don't know why it doesn't work.
Thanks everyone for your replies. Have someone checking it out. If problem not solved before we go will wait until we get to Darwin and hopefully Jayco can solve it for us.
Please let all know problem and results.
j.ballard
The Happy Helper
Our Dometic 3 way fridge has been terrific, until a while ago, would not work on gas. Fridge techy diagnosed computer problem, new computers, problem solved. Fridge is nearly 8 years old,now runs like new.
jules
(Ben, aged 10)
 They're good while they're going well, we bought our caravan new 7 years ago & our Dometic 3 way fridge has sh*t itself four times.
Twice not working on gas, once not working on 240v & once not working on 12v.
Next time it does it we're buying a compressor fridge.
Cheers Keith & Judy
The Happy Helper
Quite happy with ours, but woul et a 2 door if we had to chngebut still 3 way, very efficient on gas, we havefound.
jules
(Ben, aged 10)
The Happy Helper
As Rocky said, maybe luck of the draw- fridgie said 7 years was when the computers start playing up.
jules
(Ben, aged 10)
Welcome to the forum Creena
As others have already said, can you let us all know what the outcome was, as it may help others in the future
I am not a techie, but from what little I know of three way fridges
You say that you changed the battery, then I would be looking to ensure, that 12 volt is getting to the fridge
You may have crossed a wire, or blown a fuse
The "Electronics Complete" (What Jules47 calls the Computer)
Requires 12 volt to operate
The Electronics Complete/Computer controls both the 12 volt and gas side of some fridges
Hope that this info, is useful to whoever is checking the fridge
