Post Info TOPIC: Rattling Fiamma 45s awning
Has anyone had a rattly fiamma awning. Ive read you can fully extend them right out and that stops it but no... still rattles. Im in a campervan so can hear it when driving. Ive been working my way through all the rattles in the van and this is the last one. I bought some thin rubber from clark rubber to perhaps find the offending spot. Any ideas?
Lynne
Fiamma & Prostor awnings are pretty flimsy pieces of kit at the best of times, replace it with a sturdy rollout awning.
Cheers Keith & Judy
EJP
I don't have a Fiamma awning, a Carefree one instead, and it used to rattle. There are 2 rubber anti rattle stops between the vertical support arms and the fold-out arms and one of these was missing. Also the pivot pins in the top brackets had worn/broken and had been replaced with split pins (happened before I bought the van). I replaced the anti rattle stops and fitted new pivot pins and all is good. As an intermin measure, before fixing, I used velcro straps to tie the fold-out arms to the fixed vertical arms when on the road. It didn't solve the problem completely but did help until I could fix them. The rubber stops and pivot pins are available at caravan assessories stores. Hope this helps.
Regards EJP
Hi Ejp. Thanks for that. Ill have good look and see if i can see anywhere that may have had rubber stops. Ive had fiammas before and they have never been as noisy as this one, so you are probably onto something.
Lynne
