Post Info TOPIC: Projecta IC5000
Projecta IC5000
Hi Guys,
 I have just fitted a projecta IC5000 battery charger to our van
was tight fit
Also fitted a ProStar 30amp solar controller
I fitted a PID and a thermo couple so I can adjust the temperature
via a PC 12volt fan
all works extremely well with the door closed  the temp at 27 degrees
neat job!
Hey Bukhouse. Nice work. Where did you get the Pid and thermocouple from?
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
Hi,
The  "K" thermo couple is off eBay and also the  Inkbird
PIDhttps://www.ebay.com.au/itm/FAST-RESPONSE-K-TYPE-AIR-TEMPERATURE-SENSOR-FOR-DUCTS-VENTS-10-200deg-C/272786972196?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
https://www.ebay.com.au/itm/ITC-100VL-PID-Digital-Temperature-Controller-Thermostat-Temp-12V-24V-fridge-fan/222308504112?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
https://www.ebay.com.au/itm/Sunon-High-Performance-Cooling-Exhaust-Fan-12v-120mm-F1165-suits-19-Rack-System/371032050047?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Thanks Bukhouse for the links. These may be very handy.
Tug 2016 D-Maxine
Den 2009 Goldie RV
