SmartBar SmartBar
Post Info TOPIC: Projecta 25a 7 stage charger any better alternatives?
Hi All
My projecta 25a charger has died on me after 5 years - there is no power getting so the thing is basically dead. the question is Is it repairable ? if no can anyone recommend a suitable replacement?
thnx M
-- Edited by Muffer on Monday 19th of February 2018 07:07:51 PM
Muffer wrote:
Hi All
thnx M
 Will be more economical to simply replace.  We use a 50 amp Projecta.  One of the best on the market IMHO.
Kevin Kyle
On the road full time with Son and 21 year old cat and 3 year old Manx.
Toyota Landcruiser 100 series V8.  Nextgen semi off-roader.  3 120 AH agm batteries, 1KW Solar
There is a fuse inside but you have to have the skills to open it up. Worth a check, those are good chargers.
If it really has passed on then I'd look at the IC5000 model from the same manufacturer. I've yet to see one actually die, the most common fault is broken voltage sense wires that run through the centre of the charging cables.
T1 Terry
It doesnt power up so no lights at all - where is the fuse located ?
The fuse is on the board virtually behind the fan and marked F1. Printed on the circuit board of this IC3500 I just modified for external battery voltage sensing, the fuse is listed as 10 amp for the 3500 and 12 amp for the 5000. It is white in the centre glass part and plugs into a soldered on cap at each end.
The DC output is protected within the circuitry on the smaller output models so no fuse is visible, from memory the 50 amp unit has 2 50 amp blde type fuses in parallel roughly centre of the board.
T1 Terry
