SmartBar SmartBar
Post Info TOPIC: What size charger?
What size charger?
Ok punters, what is the optimal size 240 volt multi stage charger to charge 240 amp of agl batteries? (2x120 amp, paralleled)
Cheers, John.
25 amp
the seconds keep on ticking away
10 % charge
meetoo, batteries are best charged at the 10 hour rate so both Aus-Kiwi & dazz are right on the ball.
Have a read of this - www.energymatters.com.au/components/battery-voltage-discharge/ The only link that I had to EM was to buy a couple of portable panels from them a few years ago but I find their info very good. I have a copy of the voltages printed & in my van's hand book.
Or larger..........
HI
The charge rate is typically higher for AGM compared to wet flooded batteries
Typical
AGM charge rate
wet batt = slow 10% upto 20% of AH
AGM batt = slow 15% upto 25% of AH
[technically agm rates are only limited by there temperature]
Batteries can have specific conditions for charge so its always recommended to follow the guidelines by the maker.
In reality 2x 120ah are charged by 240v 25amp or a 40amp charger . If u bush camp alot your generator needs to run the charger .
Going below 25amps will extend the run time on generator potentially to eg 8hrs +
Thanks all. Great to see a close agreeance between replies. Makes it easier to choose one. Looks like it is a choice between 25 amp and 25 amp. Hmm, I think I'll choose 25 amp.
Cheers, John.
