Post Info TOPIC: Replacement lights for Avan
Hi all,
newbie but an oldie here. Just bought an Avan Leah and the lights are as shown in the pic. They have had a tough life and corrosion means I'm going to replace them.
Does anybody know where I can get a LED set, (I'm in Adelaide), which will interchange/fit in the alcove the originals are in? I've talked to the Avan dealer and looked at fleabay with not much luck
so hoping there may be another Avan owner who can pass on some help.
Hi mate. If you can measure the outside diameter and the mounting hole pitch it would be easier to assist. Most LED fixture manufacturers make a round model...
www.keoghsmarine.com.au/index.php They are Qld based but should be able to point you in the right direction.
