Post Info TOPIC: 1987 Toyota Coaster rear sway bar assembly
Can anyone help in sourcing a rear sway bar assembly for a Toyota Coaster/Dyna?
Regards,
Gurdymotor.
0401 650 456.
Gurdymotor.
www.ebay.com.au/sch/sis.html Personally I would contact Hayman Reece Dealer.
Sway bar for roll on bus or for load on tow bar ? My old Fuso converted 9m bus . I used a bar  from a latter model . Made steering way better . Being a pusher ( engine in back) with much more weight .
-- Edited by Aus-Kiwi on Thursday 25th of January 2018 03:34:05 PM
It is for reducing roll in the rear which will of course sharpen up the steering.
Gurdymotor.
Regards,
Gurdymotor.
0401 650 456.
Howdy Gurdymotor,  A Big welcome to the Forum,
I owned a 1977 Coaster bus a few years back and had the same problem that you have, On close inspection I found all the rear spring bushes were completely worn out,
After I replaced all bushes with new Neoprene ones, I found the old Girl handled a heck of a lot better with reduced sway.
K.J.
From Coast to Coast, We'll see it all.......One Day
U.H.F  CH  18 /40  Say G'day.
Thanks for that info but I really want a sway bar as the bushes are all new in this one. I am a suspension specialist and just want the hardware for the roll bar - I can easily make one but I just want to shorten to delivery time.
Gurdymotor.
I have an ambulance sway bar that came with 9â diff . Try http://www.whiteline.com.au/vehicle_swaybars.php
Regards,
Gurdymotor.
0401 650 456.
 Hi Gurdymotorsmile
Here is a part number for a '99-'04 Toyota Coaster - HDB50 rear bar. You could try searching ?? toyota 48812-36030.
But really any suspension specialist place could make one up and fit it with standard after market parts. Or try the truck wreckers as there may be some left on their stock. There are Coaster bus wreckers if you search.
