SmartBar SmartBar
Post Info TOPIC: toilet cassette
toilet cassette
having trouble with liquid on top of cassette when removing from van any help or tips would be appreciated.
Ted
Wait a few moments after flushing before closing the flap.
Thanks but have tried that. I have even dismantled the cassette cleaned and lubricated moving parts, but still there is water when I remove it.
Ted
Most likely a damaged or worn seal. I had a similar issue & priced a set of seals at about $78 but decided to go with a complete new tank at $128 delivered from CaravansPlus, that was about 3 years ago.
Thanks for your help .  Looks like that's the way to go.
Ted
 Same thats what I did,fixed the problem.Then carried the old one around for ages thinking to use as a spare, never did chucked it out .
Dhutime
My suggestion is to fit a new lip seal.It fixed our leak last year.From memory the seal was about $25.
I like to see a little bit of water remaining on top of the flap seal after flushing as it helps to keep the seal from drying out and keeps any smells out of the van.
When it's time to empty, simply slide the cassette out a little, turn the yellow knob enough to let the water drain into the cassette, close the flap again and pull the cassette fully out.
If you're getting any water into the bottom of the cassette compartment you could slip a couple of bits of lino under the cassette to pack it up a bit and make the seal a slightly tighter fit.
Bruce
My suggestion, when it is time to empty the cassette go inside & open the flap a bit, let any water drain, close flap, go outside & remove the (dry) cassette.
You're welcome, biggrinbiggrin
Neil & Lynne
Pinjarra
Western Australia
