Post Info TOPIC: 12 radio
12 radio
I hope some can help me. the 12 volt radio in my caravan will flash, on and of with the 12 volt power and 240 power turned of to the radio, Have tried reset nothing.
Regards, Bowser.
Sorry if this is off subject but I have an LED 240 volt house hold light that does that long after it is turned off.
with ours the lights were on all the time even when it was turned off. Pulling out the fuse and putting it back in fixed the problem.
I have taken out all the fuses, but that has not worked at this point, But I can give that another go.
Regards, Bowser.
Most radios in cars and vans have a constant electrical feed, otherwise all the presets would be lost every time you turned it off. Disconnecting the battery will take it back to nothing and you have to set the clock and stations again. If you've done this, then the flashing is quite normal and has to be adjusted via the menu settings in the radio itself. Is this your issue? Before I launch into a long convoluted explanation, a bit more info from you about the make of radio would help. I know a few Jayco owners who used to take the faceplate off their radios at night because the light flashing kept them awake. Not necessary if you use the menu to kill the display when the radio is off.
Back to you.
Thanks Kevinc
JVC / DVD/CD receiver
I have stopped the flashing, now a cd is stuck, following the book I can not get the cd out, It will not stop at any radio stations just keeps rolling around.
I am still working on it.
Regards Bowser.
Thanks to all for your help. had the radio checked today, it is dead. will get a new one next week.
Regards Bowser.
Bad result, but thanks for the feedback.
Get a bluetooth one as they are great I listen to my favorite radio station wherever I go via my phone, Also can listen to songs on your phone.
Toyota Coaster
Allan
Yes . Just be aware some blue tooth phones only have blue tooth for hands free .. Bot the full system .
