Post Info TOPIC: Harrier Air Conditioner
I have the legend of error codes for new Dometic Harrier Air Conditioner if anyone wants a copy. New to forum so I'll need help to upload 3page pdf. Suprisingly these error codes are not in the user's manual. The error codes are displayed on the internal fan unit whenever there is a problem but unless you have the error code legend what good are the codes as they mean zipo :)
Hi Garry,
Reckon I could find these handy one day, so if you can attach them as files I for one would appreciate it.
It's the bottom button in the reply screen.
Thanx,
Bernie
Any chance that the PDF could be uploaded? I know of someone chasing help with code "EA", so even just the meaning of this particular error would be appreciated. š
 Just below the text area where you type whatever to post there's a Grey Button "Attach Files", click that then navigate to where the PDF is on your computer & click OPEN then Click "Submit Post"
Hope this helps. Steve.
Hi Garry,
My new van has a Harrier and although it is working great I would apprciate the codes just in case.
Travel Safely
Did this list ever get posted? I've just started getting an EA error on my not-that-old Harrier.
I have thw error codes somewhere I will post them when I find them.
Thanks. I think the EA error was just low batteries in the remote - changing them seemed to clear it. It would be useful to have the list of error codes all the same. I've found some lists of error codes, but they were in the form of "E7", and didn't include EA.
Since this thread is about the Dometic Harrier, has anyone experienced an issue where it blows neither cold air on the cooling setting nor hot air on the heating setting? The unit appears to operate, but just blows normal air. Someone I was camped next to when I discovered this said that they had had this problem a couple of times with a similar unit, and had a capacitor replaced.
The EA error seems to have been just a coincidence.
