SmartBar SmartBar
Post Info TOPIC: jayco water pump
jayco water pump
can any one tell me how to get my water pump to work on the rear tank.
works fine on the front tank. but just spits and splaters on the rear
i have tried turning the direction tap in all directions still no joy
it,s a silverline 2015 model cheers Gazza
End of hose come adrift. Split in line.
Tank empty and needs bleeding.
Get under and look. Put hose in there. Leaking anywhere?.
I have the same model van, I would be looking for a kinked suction hose from the tank to the change over valve. What you could do is take off the hose to that tank, at the selector valve, that is giving grief, connect a short hose from the valve and put the other end in a bucket of water, if it pumps, then the problem is the suction hose or a restriction in the tank. Has the problem just occurred, or has it always been there?, I have one tank in my van, that seems to be slow, and am suspicious that the outlet, inside the tank is restricted.
 Check and tighten all connections on the hose to the rear tank.
Neil & Lynne
Pinjarra
Western Australia
Thanks Iana i will look under the van for any kinks or splits and yes it has been like that from new
i did call jayco in perth with no real response
i don,t think there clued up on the gear they sell since shane left
Isolate the tanks using two taps and use each tank seperately. No more problems.
The tanks are connected to the pump via a cheapish selector valve, only one tank at a time can be used. In my case I am suspicious that plastic from the tank molding process is restricting the outlet behind the screwed in tank outlet fitting. gazza I thought you were in Perth until I looked up where you live. I am contemplating moving the water pump to under the floor in a sound proof box, plenty of room under there, installing some better selector valves, and freeing up some room for storage behind the water heater.
