Post Info TOPIC: Water Pump
msg
Water Pump
I fixed my water pump without having a clue.!!!!   It had been running on after I turned off the tap for some time and was getting worse.   All I did, was take off the cover, inspected the little bowel that sticks out.  Unscrewed it looked to see if anything was blocking it and screwed it back on.   Checked everything else to see if anything was loose no luck.  Put cover back on and tested.   What???  Working perfectly!!!   Seems things can be fixed without replacing which is what I was expecting I had to do.  Sorry about the untechnical terminology maybe someone knows the correct terms.
-- Edited by msg on Friday 28th of July 2017 08:22:41 AM
That all sounds too technical for me as is biggrin
Well done Mel.
Yes its got me beat. Usually after a town water connection with pump off when we go back to tank and pump the bloody thing keeps running on. I have swapped out 2 pumps in 4 years.has to be something simple re different pressures????
If what you are talking about was the filter bowl, them perhaps it wasn't screwed tight, and was allowing air into the pump. Was it a transparent bowl?
msg
That's what it was. Not screwed on tight enough.
Glad to hear that you got to the guts of the matter so quickly...wink
Coop
Had the same problem with the pump running on recently the battery in the van must have been a bit low even though it was showing 12 volts on the meter,I checked it by hooking the car up and feeding some juice into the system with the car alternator, fixed it..
The Happy Helper
You are very clever MSG , didn't know you were so technically minded - hahahaha!!
jules
(Ben, aged 10)
