Post Info TOPIC: Thetford C200
Thetford C200
I am refurbishing my '84 Coaster Bus and have a couple of questions.
I want to put in a Thetford C200 toilet, does anyone know how much water it uses per flush?  Is one plumbed into the water system better than one that has it's own tank?  I carry about 95 litres of water on board.
The next question is about replacing the bifold door.  Has anyone done a door and if so what size did they use?  I have looked at (on the net) an Oddessy square cornered 1623 x 572mm.  This seems to be a good size, it's not much smaller that the original in height, but a bit narrower.
Any comments please
Thanks
-- Edited by rustybits on Monday 24th of July 2017 07:47:42 AM
the flush amount will depend how long you hold the button down. We have had both systems and prefer the separate water tank because in a water shortage you can use un-potable water for the loo especially as you only have 95lts to play with. I think our loo water storage tank holds about 10lts of fresh water and we can empty the loo at least twice maybe 3 times before having to refill it.
Jenny and Barry
Hi rustybits.
I have twice tried to post some pictures and info. without success and now hopefully waiting on some help.
I will try again later.
Thanks for your input, I have found further info on the toilet, the flush tank holds 7 litres, and gets approximately 5 flushes per 2 litres (Thetford's figures).  That doesn't seem like a lot of water but it will all add to the weight, if I use the Coaster water tank I won't be adding water, just moving it around to the toilet waste tank.
Thanks for trying to post some pictures robol, hope you get there in the end.
