Post Info TOPIC: Charging tha caravan from our house
Permalink Closed
Hello everyone. We have just had our new caravan delivered and are busy buying all the extras. A few friends have told me that it's easy to grind down the 15amp caravan plug so it fits into a house socket (although I understand it's illegal) Is it possible to buy a converter so that I can charge the fridge etc. from my house the day before we leave on a trip? I guess I need a converter from 10amp to 15amp. Is that correct? And does anyone know where I can buy one. Thanks in advance. Richard
Permalink Closed
www.campsmart.net.au/pod-15-amp-to-10-amp-adapter
There are cheaper ones on Flea Bay
Permalink Closed
G'day
I bought one from Jaycar. Around $80 I think. I have also seen the Ampfibian converters at Bunnings.
Brooksy
2015 Nissan NP300 Navara,  2011 21' Jayco Sterling
Permalink Closed
My son is a licensed electrician so he installed a 15amp power outlet on the panel inside my meter box now I can run a 15amp lead to the van without any problems.
DavRo
Permalink Closed
We bought a 15amp socket and modified an ols extention lead.
Only 6inchs long. Keep it in the van just incase.
Cost us around 4 bucks.
Hope this helps.
Kezngaz.
Permalink Closed
Hope this helps.
Kezngaz.
 Hmmm smile
I have got my popcorn and set up the easy chair. Waiting for the technical forum monitors to start with the lectures.awwawwaww
-- Edited by Jaahn on Monday 10th of July 2017 08:56:47 AM
Permalink Closed
I am not an Electrician so will not comment about right or wrong, but I for one did appreciate it, when the Electricians spoke up
You can buy an Ampibian as in the picture below from Bunnings in WA for $75
Note that the one in the picture is not waterproof
None of my outdoor house 10 Amp power points are exposed to any rain
You can buy a waterproof one, which will cost extra
Permalink Closed
Can easy crank up fridge with gas or amphibian if you want 240
Permalink Closed
Hope this helps.
Kezngaz.
 Sadly, you are not very cleverno
Some  forums would immediately remove your post for suggesting an illegal modification to that extension lead
I hope when your chickens come home to roost that no one is hurt or suffers losses
Permalink Closed
 Any modifacation by non licensed persons[who do not  know & understand the rules & regulations ]is illegal
Those "friends"? do not understand the risks of their actions & the trouble they could be in if something goes wrong
There are several brands of Approved 10A to 15A adapters available .
However many are not suitable for outdoor use
Can only be used under cover & obviosly for that reason are much cheaper than the few models [such as Ampfibian , Safelec ,& & ONE Jaycar model] that are fully approved for use with caravans etc in all situations
-- Edited by oldtrack123 on Monday 10th of July 2017 12:08:13 PM
Permalink Closed
10 to 15A Plugs fine.10A will restrict output up line.
In Reverse. No No.
Simple.
We used for 50 yrs and more b4 Big Brother rools took over Australia.
As with a lot of other "No No" items.
used sensibly. They ain't a problem.
Permalink Closed
In Reverse. No No.
Simple.
Please explain how you come to that stupid conclusion???
That a simple PLUG can restrict the current??noconfuse
In fact totally wrong ,which is why such is illegal as it is not approved for use ANYWHERE
BUT a 10A plug is quite acceptable in a 15A socketr
 Just  a little electrical knowledge is required to understand the simple reasons
-- Edited by oldtrack123 on Monday 10th of July 2017 05:10:58 PM
Permalink Closed
macka17 what restricts the output ???
if you start to draw 15 amps it will do it then get hot and maybe
short and blow breaker or burst into flames.
these could be at the extreem end but my point is there
is nothing to restrict current flow as you suggest
regards
Permalink Closed
 Welcome to the forum.
In my opinion this is the best of all solutions BUT get a licenced electrician to do it and a certificate of compliance.
And now the popcorn and coldie..
-- Edited by Phil C on Monday 10th of July 2017 05:24:01 PM
Permalink Closed
regards
 Exactly
 The 10A outlet could be 50% overloaded as it is only designed to carry 10A continuously[without over heating]
If an item has a factory fitted 15A plug fitted it is because the continuous  load current exceeds 10A
The outlet itself is protected by the appliance plugged having the correctly rated plug
THAT applies to ALL plug & socket combinations even up to 100s of amps
Also that actual wiring feding that 10A socket may be rated @20A & protected by a 20A circuit breaker as Multiple 10A will usually be on that circuit
Permalink Closed
Hi all,
Please be aware that although we do have many knowledgeable members who can offer great advice on general technical issues, if you have specific electrical problems it would be safest to consult a qualified expert.
