Post Info TOPIC: Wren rooftop air con
Sorry but maybe an stupid question
Will the Honda 2.2  be able to run Wren roof air con ??
Cooling output:    3.0 KW
 Heating output:    3.0 KW
In an Coromal Princeton 702
thanks John
-- Edited by Cruising Cruze on Wednesday 24th of May 2017 05:48:38 PM
Hey CC, you do'n renos mate?
We run the Dometic AC off 2.2 Honda inverter - ensure that other 240V appliances off. Works well when cooler but it feels the load on heating.
Hi Collin
Once again mate thanks for the info
Cheers John
Hi Doug
From day one we've been jealous of your aluminium teepee biggrin
So we were going to look for some thing like yours
Mate it took a bit and I tell you that for fee,but we think we found the one we like ( and we can afford )
Looking at an Coromal Princeton 702
My only concern so far is the length of it 22 ft and that is holding me back a bit
But Marjoleine loves the setup of it,  So who am I ??? to say no biggrin
I think it is 3 ft longer than yours
we wait and see what is going to happen not in an rush yet
Cheers John
Mine is 20ft John. I did a search on Google and came up with a second hand one in HB, is that it or are you going with a newie. I found one of those with a slideout. Will you get it around the back?
Hi Doug
It's the one with single beds
Yes that is the big problem in my opinion
Neighbor next door with 19 ft van told me this avo it should be no problem
Otherwise I have to reverse it in
wait and see
Want one of my mates opinion as well
So not in a rush at the moment if it sells in the mean time,well bad luck than
Every thing happens for a reason did not meant to be than if sold
Cheers John
