Post Info TOPIC: Cassette toilets
ken
Cassette toilets
Hi all. Ok composting toilet seems to be just to hard. So back to cassette type i have contacted dometic and thetford looking for a front access cassette toilet but like hens teeth any one have a suggestion?
We have a Thetford C263, which has a bowl that can be turned 90 degrees would that suit? Looking at their C402-C model, could you mount that against rear wall of you ensuite to obtain a side entry to access cassette? www.thetford-europe.com/au/product-category/toilets-au/cassette-toilets-toilets-au/
Hello Ken
I give the same information as Possum3, with a bit more added
I have never heard of a front access cassette, so I can not help you there
Looking at my own cassette it says Thetford, but I can not see a number on it
It has a swivel base, and the height of the cassette under the floor looks about (I did not measure it) 200 mm high
I suppose if you really, really, wanted a front access cassette.
You could make a box to suit the cassette
Have a hinged step in front
Walk up to the throne
And at the appropriate time, swing the hinged step away, to withdraw the cassette
An alternative is to use a porti potty
They come in two halves, so you can remove the top, and carry the bottom half away
Hope that this info is useful to you
As a sidenote
I do not know what type of RV you have, but I do not think that my own Mrs Tony, would allow me to carry a cassette through the living area
msg
I'm with you Tony, couldn't think of anything worse. Outside access for me.
Wrong thread sorry
-- Edited by Dougwe on Saturday 8th of April 2017 04:54:30 PM
Ken, Is it permitted to ask why you want/need a front access cassette toilet it would seem to be very unusual?
Kebbin
Bit off topic...(sorry), but am searching for small trolley/sackcart to wheel our cassette to dump point.
Doesn't bother me to drag it thru a busy park...will just put a collar on it and change it's name to "Lassie"  lol
Kalangadoo with a wheel barrow & water bag
Good one OG.
Maybe just do this
Heaps on ebay around $30-40, small gen purpose trolleys that fold flat. OR, buy a $15 shopping jeep from $2 shop or similar junk outlet, discard the bag and strap the cassette on the frame with occy strap. I've seen one in action, although it won't last a lifetime of rough ground travel.
 The moral: Focus on the Facts
Top idea Tony.....thanks.
Am a little daunted with entering $2 shops.....come out with items I might use oneday....lol
ken
Im trying to fit a toilet to a vehicle that has made it impossible to get outside access. Now im stuck with front access.
Hey Ole Grizzly
I have a small foldable trolley I carried a suitcase on years ago. See attached link for similar idea
https://www.amazon.com/BOSON-Lightweight-Folding-Transport-Grocery/dp/B01N4FLI0E/ref=sr_1_3?ie=UTF8&qid=1491801275&sr=8-3&keywords=small+luggage+trolley
Hope this helps.
Diamond
Diamond
Thanks for that info Diamond.....looks like the ideal unit for taking cassette for a walk to loose weight..lol
I have no idea how that Amazon site works being US.  So will search for it or very similar here in Oz.
Thanks again.....Cheers
A few more trolleys to consider : www.ebay.com.au/itm/Collapsible-Trolley-New-Caravan-Portable-Toilet-Accessories-Camping-Water-RV-/351838305896 & www.officeworks.com.au/shop/officeworks/p/pack-and-roll-trolley-cart-35kg-lecprtc01
Bill B
Update on my last post: In Bunnings yesterday I noticed a batch of these general purpose small trolleys, the carry ledge and wheels fully fold flat - $29.95 (i.e. if you don't want to rummage around the $2 shop or pay ebay postage).
-- Edited by SouthernComfort on Wednesday 12th of April 2017 08:06:07 AM
Maybe you could try the marine suppliers. They may have a vacuum system that would allow you to mount the cassette on an outside wall and have the bowl in the middle of the vehicle.
ken
Thanks all ive told my wife im cutting a hole in floor and it can be a long drop. Apparently the tow hitch get comfortable after a few weeks of sleeping there.
