Post Info TOPIC: Wineguard Maintenance
Reminder to everyone to maintain your wineguard  aerial regularly - they say at least every six months
For those who don't know how, here is a link to a youtube video to help - we found it quite useful.
https://www.youtube.com/watch?v=KATPS5bU0nY
Thanks Dunmowin, useful information, any maintenance will save money & inconvenience down the road. Cheers Pete
Thank you from us Dunmowin,
I sprayed our previous caravan Winegard with WD40 but we didn't have tv so I don't know if it did any harm to it as I read in a mag you should lubicate your winegard once a year.
With our second hand new one it has a winegard and a tv, I was thinking just the other night after Marilyn spent about a hour trying to tune it in and failed to get New Tricks at Bendamere maybe the winegard needs a service, I am carrying a can of silican spray now to find a tall tree to climb to get to the roof of the caravan.
All good. Radar.
Thanks for that link Dunmoving, I am sure that this information will help others, in the future
In 2014 when I purchased my present second hand vehicle, the Winegard antenna was stuck solid, and the previous owner had broken the handle trying to raise it
At that time I could not find any info on how to dismantle it
I done it the hard way, by removing everything from the ceiling, removing the bolts from the roof, and pulling the complete unit off the vehicle
When I had it on my bench, I then saw how easily it comes apart
Viewing it from a ladder, I was expecting it to have circlips, or other fasteners, holding the mechanism inside the housing
I suppose that this is a case of easy when you know how
I can vouch for this mtce regime.
Mine was hard & jerky to wind up so I did the suggested mtce.
Good as new.
I suppose that I was slack in not sharing but in my defense I think that I got the tip from a previous post.
Thanks for the heads up Dunmoving.
Going off topic as usual ..
Talking about Van Mtce ... Just ordered a replacement for a 20yo vent lid that cracked & leaked on the last trip.  Good article on identifying vents type on Caravanplus site. Easy job to replace.  Next re-caulk roof.  Not so easy.
I think I posted this once before - a couple of years ago - but it is good to be reminded anyway
Thank John, I'll check mine before we leave Toowoomba after Easter.
I see there's no rain at home yet & the Ross Dam is still at 18% full. This year could be very interesting if there is no more rain!
The council didn't realise that they had a problem until too late & it has cost them big bucks to pump from the Burdekin, the State Govt (with their Green mates - no more dams) isn't interested even though the Feds have dished out some funds toward doing something about it!
PS - Radar - New Tricks is "Old Tricks" - replays! Still a good show.
Thanks Dunmowin.
I'll be doing ours today.
For the past 5 years we've been spraying ours inside & out 3 times a year with INOX LUBRICANT. www.inoxmx.com/uses/mx3-applications-uses/
So smooth to wind up & down.
Cheers Keith & Judy
Guys, If you read the wine guard antenna maintenance section in the manufacturers booklet it says not to use WD40 as it damages the gears, use a silicon spray and then wind the antenna up and down 3-4 times after spraying.
